1. Guest,
Weird question about Mac Pro & additional hard drive
Discussion in 'Apple' started by MatthewA, Nov 7, 2008.
  1. MatthewA
    MatthewA Well-Known Member
    Apr 19, 2000
    6,841
    699
    Salinas, CA
    Matthew
    I have a Mac Pro, and I also have a LaCie 500GB Big Disk External Hard Drive than went poof last year.
    I wonder if it is at all possible to retrieve the data by taking out the two hard drives from the LaCie and putting it into the Mac Pro.
  2. Carlo Medina
    Carlo Medina Well-Known Member
    Oct 31, 1997
    10,343
    562
    Depends on what you mean by "went poof". If it's a problem with the enclosure, and the disks are fine, you might be able to do what you propose. If the hard drive crashed (head crash, or other hardware failure within the drive) then probably not. A crashed disk is a crashed disk no matter if it's in the enclosure or in your Mac Pro.
  3. Ken Chan
    Ken Chan Well-Known Member
    Apr 11, 1999
    3,302
    If it was two 250GB drives striped together to make 500GB, then it's a bit trickier, since to read them, the RAID controller -- hardware or software -- has to stripe them the same way to see your data as it was. Otherwise it's a jigsaw puzzle.
  4. MatthewA
    Apr 19, 2000
    6,841
    699
    Salinas, CA
    Matthew
    Ken is correct. It was two 250 GB drives.
    There was a chip that caused them to read as one. That chip failed.
    I recently installed an additional 1TB of space. All I want is the data back.
  5. Ken Chan
    Apr 11, 1999
    3,302
    I would contact LaCie and see if there's any technical info that might help. You may be able to do software RAID directly on the Mac.
