1. Guest,
Wal-Mart HDTV claims
Discussion in 'Playback Devices' started by Dave Schofield, Jun 20, 2004.
  1. Dave Schofield
    Dave Schofield Well-Known Member
    Sep 30, 1999
    403
    I visited my friendly local mom and pop shop (otherwise known as Wal-Mart) the other day and noticed a sign next to their HDTV's that said, and I paraphrase:
    Now, I won't claim to be all that knowledgeable regarding this sort of thing, but it would seem to me that this is blatant false advertising, isn't it? Wal-Mart wouldn't lie, would they? [​IMG]
  2. Dave Schofield
    Sep 30, 1999
    403
  3. Jack Briggs
    Jack Briggs Well-Known Member
    Jun 3, 1999
    16,740
    129
    It is blatantly false.
    Eventually, tuner/decoders will be available that allow NTSC-only sets to receive and display ATSC broadcasts, but only at the sets' native 480i resolution. In no way will doing such "improve" the picture. Your friendly little "mom-and-pop" store is taking advantage of most people's ignorance about this subject (remember, the majority of citizens in this country do not even know what HDTV is).
  4. Jack Briggs
    Jun 3, 1999
    16,740
    129
  5. Don_Berg
    Don_Berg Well-Known Member
    May 30, 2003
    931
    Watching digital TV on an analog set does offer some improved issues compared to analog TV reception, no snow or ghosts - but not higher resolution.
  6. Don_Berg
    May 30, 2003
    931
  7. RobertR
    RobertR Well-Known Member
    Dec 19, 1998
    9,663
    153
    I find that the picture on my analog set from downconverted HD channels is noticeably better than it is from any other source, not because the TV functions better, but because the source is the highest quality available (maxed out resolution, zero chroma noise, no noticeable mpeg artifacts, etc.).
  8. RobertR
    Dec 19, 1998
    9,663
    153
  9. StephenHa
    StephenHa Well-Known Member
    Sep 28, 2003
    364
    it's just like digital cable or sat. has a better picture than traditional antennae because it's freeer from defects (notice not free that will probably never happen)
  10. StephenHa
    Sep 28, 2003
    364
  11. Chris
    Chris Well-Known Member
    Jul 4, 1997
    6,790
    The again, the display technology in most HDTV sets is better then the comparable set sold at Walmart.. so, if you're comparing a cheap HDTV set to a cheap set-top set, yes, even with the same source material, one will look better..
    Not because it's HDTV, but because it's built better then a cheap set [​IMG]
  12. Chris
    Jul 4, 1997
    6,790
  13. StephenHa
    Sep 28, 2003
    364
    bingo, and all the sets thay have that look like the ones at regular stores, once the back is off there are differences (the shop I worked at was accross from wally world and did warranty repairs)
  14. StephenHa
    Sep 28, 2003
    364
  15. Allan Jayne
    Allan Jayne Well-Known Member
    Nov 1, 1998
    2,406
    If the TV plays DVD's with better picture quality than ordinary broadcasts, then that quotation from the Wal-Mart sign would be true.
    I disagree that your mom and pop store is otherwise known as Wal-Mart. Instead your mom and pop store is the kind of store that goes out of business when a Wal-Mart opens nearby.
    Reminds me of a sign in a Sears store explaining the difference between interlaced and progressive. I don't remember the details but what was said was misleading. Incidentally an HDTV program for an HDTV retail store demo feed unit could be prepared that gave a reasonable rendition of interlaced NTSC video so that on the same TV set a prospective customer could see the difference in an alternating scene or even split screen comparision.
    Video hints:
  16. Allan Jayne
    Nov 1, 1998
    2,406
    Video hints:
  17. Iver
    Iver Well-Known Member
    Sep 23, 2002
    324
    Most STB's have a 480i output option, via either composite, S-Video, or compoNENT connection, which will work with that type of input on an NTSC TV. The picture will be better quality than OTA NTSC and should definitely be better than digital cable.
  18. Iver
    Sep 23, 2002
    324
  19. Steve Schaffer
    Steve Schaffer Well-Known Member
    Apr 15, 1999
    3,759
    HD downconverted by the receiver to 480i (and all stbs can do this) will look at least as good as dvd, far better than any cable signal and also better than probably 99% of over the air ntsc signals. I've tried it myself and it's true. The result reminded me of the crystal clear image we got from DirecTV back in 96 before their SD pq went to hell from overcompression due to cramming in too many crappy channels.
  20. Steve Schaffer
    Apr 15, 1999
    3,759
