Turntable preamp question (1 Viewer)
Thira
Just added the HK 7200 to my home theater. Previously I was using the Yamaha DSP-A1 which had inputs for my turntable.
Does anyone have a recommendation for a preamp for my turntable?
Secondly, which input should I connect the turntable to my HK 7200?
Thank you
Scott_N
What is your price range? What kind of cartridge are you using MM or MC? Any of the analog inputs on your reciever should be okay and I would use the stereo direct mode if your receiver has this.
Thira
I have a magnetic cartridge. I would like to stay under $250 and prefer a quality piece.
Scott_N
The Creek OBH-8 is a nice phono preamp in that price range. It retails for $199 and there many Creek/Music Hall dealers.
Good luck with whatever you choose.
gregD
Phono pre's at all sortsa price points, including 'insane':
http://makeashorterlink.com/?I283424B7
The one not shown that I use is a Parasound PPH-100... a real overachiever at $120.
The Creeks are a good value.
If you can spend a little more, the Lehman Black Cube is regarded as a world-beater at $470... have not heard it myself, however.
Happy hunting.
Scott_N
The Black Cube is a very good preamp for the money and Stereophile rated it Class B. One just sold on Audiogon for $300 so a used one might be in your price range. It has much better bass and detail than the Creek and compares with preamps twice it's price.
NickScott
I just bought the NAD PP-2, you can use a MM and MC and I paid $150 can. for it. It sounds great and its a great price.
It was rated the best phono preamp last year for the price in the UK. And I agree with that.
Plus its really small, maybe 5 X 3 X 1.5", so you can hide it anywheres!
Thira
Thanks so much for the direction in the worlk of phono preamps. I considered the Creek OBH-8 and Parasound PPH-100, and decided to purchase the Creek. NickScott, I might have been a bit too impatient as I went ahead and ordered the Creek. But the NAD PP-2 sounds very interesting and maybe for the price would have been my choice. The Black Cube was more than I wished to spend. Others in the thousand of dollar price range were a bit too outrageous for me. For the price of some, I could be listening to the waves of the Agean Sea on a Greek Island with some beautiful woman next to me. Just a thought. ANd another perspective!
Thanks all!
Larsenv
