I have an epson 8350 projector and an Elite spectrum screen. I originally bought a cheap mono wire from radio shack to test the trigger out and it worked fine. I then purchased a longer (35') cord from monoprice and for whatever reason, can't get it to work. The monoproce cable has two wires joined together. In each wire there is another with bronze wire wrapped around it. There is a red wire and a white wire. The cable from the screen has a red wire and green wire. I've tried every combination to connect those wires to the wires of the trigger cable provided by elite but nothing seems to work. In the attached image, the monoprice wire that runs from the projector is on the right and the wire from the screen is on the left. How should these wires be connected?
Any help would be greatly appreciated!
Eddie
Eddie
