1. Guest,
SVS PB12-Plus/2 or Paradigm Servo-15 v2
Discussion in 'Speakers' started by electra1027, Oct 21, 2006.
  1. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    I'm going to buy a new subwoofer for my HT. I've 2 temporarily options in my mind, one is PB12-Plus/2 and the other is Servo-15 v2. I tested the Servo-15 not long ago and it gave quite a good impression to me, especially playing for music. It was tight and went coherent with the front speakers. On the movie side, it performed ok too, but I expected a bit more from it, like went deeper, more exposive,... On the other hands, I'm thinking of PB12-Plus and I assume it would be a candidate to consider. Unluckily, I don't have any experience on it. Could anybody share any experience to me?? Thank You!![​IMG]
  2. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    Please give me some thoughts...
  3. mr.H
    mr.H Member
    Aug 26, 2006
    16
    Hi, If you are in the USA, you can try the SVS PB-12/Plus2 for 45 days and return it to them if you think you don't like it and you get you money back no questins ask. But I think you will never return it coz you'll gonna LOVE it! Good Luck!
  4. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    I'm actually in China, so the return policy doesn't seem too useful for me... that's why I truly need some help here. Unfortunately, so far you're the only one who gave me the information. Anyway, thank you!! I appreciate for that!![​IMG]
  5. Jack Gilvey
    Jack Gilvey Well-Known Member
    Mar 13, 1999
    4,952
  6. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    Thanks for providing me the link!! Actually, I did read them before. What I'm looking for is some sharing from the existing or past user(s) of these subwoofer(s) about how much they enjoy them. Also the strength/characters of the subwoofer,... Thank You, anyway!![​IMG]
  7. mr.H
    mr.H Member
    Aug 26, 2006
    16
    Hi again Cheung,
    Actually I have a PB-12 Plus
  8. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    Thanks in advance!! I'm looking forward to your post very soon... Any other thoughts are also very much welcomed!!
  9. John Garcia
    John Garcia Well-Known Member
    Jun 24, 1999
    11,572
    23
    NorCal
    The Servo 15 is a great sub, but it has absolutely no chance against the Plus/2. The Plus/2 will have quite a bit more output and extension. If you are more concerned about musical performance though, the Servo 15 may be a better choice or even the Velodyne DD-15 - they are cleaner in presentation overall due to using sealed enclosures, but when looking for the really low stuff, the vented SVSs really deliver.
  10. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    Thanks for your valuable input!! That's what I thought as well... You may know that I do want to get BOTH strength, but I understand that would be in another price range I suppose... maybe I'm wrong??!!
  11. MikeNg
    MikeNg Well-Known Member
    Jan 22, 2004
    440
    Hi Cheung,
    This is a departure from your choices, but I know that AV123 builds their subs in China. Perhaps they might be able to work something out with you as far as demoing a product. Their subs generally don't go as low/loud as some of the SVS offerings, but they are quite excellent for music. You might be able to get enough room extension to be satisfactory for cinema use though. As a company, they are like SVS - outstanding in every respect.
    What would it cost you to ship an SVS to your home? You may be able to save some money buying a sub built in China. Heck, isn't EVERYTHING built in China? [​IMG]P
    Anyway, in much the same way one would recommend Canadians to check into Paradigm's offerings (their built there) it may be worth it for you to check into a Rocket (AV123).
    http://www.av123.com
    Mike
  12. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    According to the review, its quality doesn't look as great as other two, PB-12Plus/2 or Servo-15, or even Ultra/2... So I'm more focusing on the latters, not the one you suggest. Anyway, thanks!! Still waiting for more sharing on the other subwoofers...
  13. John Garcia
    Jun 24, 1999
    11,572
    23
    NorCal
    I think AV123 has their cabinets built in China...and if I'm not mistaken, SVS may also.
  14. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    but I don't think they sell any of their products here...
  15. Jack Gilvey
    Mar 13, 1999
    4,952
  16. electra1027
    electra1027 Member
    Oct 18, 2006
    17
    That's what I thought too... Thanks Jack!! BTW, are U the owner of either subwoofer, I mean PB12-Plus/2 or Sevrvo-15?
  17. John Garcia
    Jun 24, 1999
    11,572
    23
    NorCal
    It would likely take 3 or more of the UFW-12s to equal a Plus/2 IMO. I know they don't sell their products there, that wasn't what I was getting at.
  18. Dan Keefe
    Dan Keefe Well-Known Member
    Jun 28, 2000
    409
    I bought the PB12-Plus/2 a month ago...the thing is as impressive to look at as it is to listen to. I have heard the Paradigm in a Home theater setting. I auditioned it as well as several other Paradigm speakers.
    The Servo 15 isn't even in the same league. I believe it is more expensive also.
    The SVS is without a doubt the best sub i have ever heard. Now I grant you there maybe other subs above this price range, but I haven't heard them.
    Be certain that no other sub in this price range IMO can touch SVS
  19. jdiddy
    jdiddy Member
    Sep 17, 2006
    17
    I have recently purchased a PB12-Plus/2 and I love it. I have to agree this thing is big and sounds as awesome as it looks. I used to have some Definitive Technology 18" subs and they just don't sound as good as the Plus 2. I don't think you will be dissapointed with buying the SVS. I hope this helps.
  20. MikeNg
    Jan 22, 2004
    440
    If AV123 doesn't sell any of their products in China, then it's a level playing field. Just trying to determine the best bang for your Chinese buck! May be worth dropping the folks a line anyway.
    As far as output, it really depends on the application. The SVS may have more output than an offering from AV123, but you'll never tap into it in a small room. In my medium sized room the UFW10 was better on music than my PB12-ISD/2, but the SVS rocked the house when I was in 'cinema' mode. It all depends...
    I've had two subs from SVS and one from AV123 - solid products all the way 'round.
