steve nn
- Jan 12, 2002
In your case Ian you might want to calibrate to -65 knowing that you are calibrating at -10 under reference. The outcome would still be the same unless we get nit-picky about how some receivers channel levels can change a little as the volume scale goes up. You could do this with your master volume set to -10 and still would be a very close reference for you. Using this method>> At 0 you would be at reference then.
