Tom Vodhanel
- Sep 4, 1998
>>>Are you comfortable matching up your PB1-ISD with the STF-3?
Ed you know as well as I do that more drivers does not mean lower distortion. Look at mutiple driver speakers for an example.Also there is an interesting thread over at AVS about distortion levels of a single driver Adire Sadhara vs the quad driver B4Plus.If we are discussing the same subwoofer, it does mean lower distortion. Two stacked VTF-3's will exhibit roughly half the distortion of a single VTF-3 at the same sound pressure level, all other things being equal.
The problem with the Sadhara and "Big Four Plus" THD data is that it was generated by different testers, in different environments, with different equipment, and different methodologies.
I can tell you from my limited experience with testing rigs that THD can be introduced into the signal by many things other than the subwoofer itself. The software and hardware gain settings, the mic, and the inherent limitations of the sound card, just to name a few. Overload (even by a frog's hair) any one gain stage or piece of equipment, and harmonics start to climb very quickly.
If anyone really wanted to legitimately compare the distortion products of the Sadhara and the B4-Plus, it would have to be under identical test conditions with the same measurement rig.
The nice thing about shoot-outs using the same test rig is that any anomalies or distortion introduced by the test rig will be the same for both subs and will cease to be a variable. The reviewer doesn't necessarily need "absolute" data; he needs to precisely measure the relative differences between the two products.
This concept can be likened to a scale that reads 180 pounds when a 165 pound man steps on it. The scale is inaccurate in that it does not reflect his actual weight. But if the man loses 6.5 pounds, the scale reads 173.5 pounds, indicating it is precise regardless of its inherent inaccuracy with respect to an absolute standard.
Ed
Also there is an interesting thread over at AVS about distortion levels of a single driver Adire Sadhara vs the quad driver B4Plus.That actually was a joke review...measuring only at 100dB. The point you are making is what...are you refering to XBL^2 motor topology and related distortion figures? So we have a single driver sub producing slightly less distortion numbers at a 100dB output level than a much larger sub using 4 drivers.I am even more impressed with the B4 and it's plus drivers...Bravo SVS! The B4 would crush the Sadhara and the fact you would pull some miniscule worthless piece of data out of that goofy review is suspect. Let's compare distortin figures between the two at 25hz and 120dB.
Curtis how well do you know cschang?
You mean the Amercian built pb-1isd against chinese built stf-3?Do you think you could build your subs in China for a lessor cost and past the savings to customers? Are you saying you offer more for $600 than Hsu? Would you sacrafice sound quality for an USA assembled subwoofer? Are you saying the STF-3 should cost even less and still compete with or best the PB1-ISD? Built in America is a great idea and marketing piece, but does not mean anything when it comes to SPL, FR, distortion, or sound quality. I know you have your reason for keeping assembly in the USA, and I commend you for it, but it doesn't make the subs sound better.
As for that Sadhara thread...some of it is a bit suspect. But the point is that 4 drivers may not mean lower distortion at lower levels like Ed stated. But Ed is right, not the same testing environment. It would be another interesting test to pick a given output level and measure distortion.
Like always with this debate...we will go around in circles. I am looking forward to what Mike writes, and in the future what Paul Carleton of HTS is able to facilitate.
And I'm all for sending Brian subs and let him test!
Built in America is a great idea and marketing piece, but does not mean anything when it comes to SPL, FR, distortion, or sound quality.It means something to me!
I think it's called "PATRIOTISM"
Hey Curtis...I think they have some great bargains in Tehran...what do you think...or is China more palitable? Don't be so naive to think HSU is passing it allllll on to you and me. Have you looked inside your VTF-3. The "cardboard" tube they used on the port they want you to block isn't all that impressive, nor was the hum and popping problem in the VTF-3 amp (because of a poor grounding scheme in the amp design-RCA ground to the ground point for CM4 and CM5). So I am confident that they arn't passing allllll the savings on to me and you. Oh, by the way....did you modify your VTF-3 to fix the problem...because it was prevalent on every unit...until I made a spectacle of myself on every forum I could find.
I think it's called "PATRIOTISM"And I think it is great. But you can be a great patriot and own non-USA made products, just like you probably do. It is called competition, and one of the things that makes this country great. Like Tom said, they have to work on design ingenuity to keep up. Without the competition, maybe they would not have such a good product. And you won't say "My sub may not sound as good, but it is made in the USA". I would not expect anyone to say that, I'd expect people to get the best their American dollar could get.
Speaking about the Middle East and Asia. Do you know that many call centers are moving or have moved their operations to India? Just something I know because my ex was in that business. It is called the global economy, and it is not going away.
Buying products made in foreign countries benefit us Americans.
And by the way, I was born and raised here, just like the next guy. I do have relatives in China(and other parts of the world) and have talked to them about some of the things they have had to endure, and it makes me appreciate the lives and choices we have here.
Mike...you edited after I finished. Ofcourse Hsu is not passing all the savings. They are a business, but it is safe to say that they are passing some, or possibly providing a better product. But in the same tone, don't think that SVS is providing a better product or service because it is assembled in the USA. Do you think SVS would make more money if they could?
I do not have a humming problem with my VTF-3. I do hear a small pop/click when I turn the light off in my bedroom, but I heard that on the 20-39PC+ as well. The electricity is crappy in my house.
Wow, both products are so similar that any miniscule differences are probably purely subjective, I'm going to go with the one built here in America.Totally understood. But you do not know if they are that close until you hear them. Until that happens, it is all marketing.
Totally understood. But you do not know if they are that close until you hear them. Until that happens, it is all marketing.I agree. That was really just a blanket statement and not implying that any of the products mentioned in this thread are that similar, or dissimilar. I'll leave that part of the discussion to you subwoofer experts.
And you won't say "My sub may not sound as good, but it is made in the USAI agree! So you are saying the HSU product sounds better than the comparable SVS product....I am not there yet...we'll have to wait and see. My own personal comparisons between the VTF-3 and the SVS 20-39PC+ did not reveal as strong of a subjective impression as you seem to be conveying. I thought they sounded very similar with the 500W bash amp appearing more robust. I have always felt the VTF-3 would benefit from more wattage....and now it does with the MK2.
