1. Guest,
Sub placement
Discussion in 'Speakers' started by Jeremy Deal, Jun 24, 2004.
  1. Jeremy Deal
    Jeremy Deal Member
    Feb 4, 2004
    17
    Setting up my speakers and I ran into a brick wall.....my wife. She wants me to put the sub in a coat closet in our living room. Before I go through the trouble of hooking it up wanted to get some opinions. Basically, the sub location is fine, but will the fact that it is behind a door make any difference and which way should the port face. Hardwood floors on crawlspace, JBL PB10 THanks!
  2. Jeremy Deal
    Jeremy Deal Member
    Feb 4, 2004
    17
  3. Jeff Gatie
    Jeff Gatie Well-Known Member
    Aug 19, 2002
    6,531
    15
    That's an outstanding spot for your sub . . . as long as you are watching from inside the coat closet. Being behind the door will eliminate most (if not all) of the sound from the sub. Even if you could hear it, the sound would be highly affected by the enclosed space and you would have to push the sub well past it's limits in order to have any appreciable output. Bite the bullet and explain to her that putting it in a closet is useless. Then buy some jewelry, or better yet, show her the furniture grade finishes available on those sweet new SVS models!
  4. Jeff Gatie
    Aug 19, 2002
    6,531
    15
  5. Scott Tucker
    Scott Tucker Well-Known Member
    Jul 22, 2002
    231
    So, if i park my neighbors Yukon in my closet, i won't be able to hear it at 1:00 in the morning?
    Scott
  6. Scott Tucker
    Jul 22, 2002
    231
    Scott
  7. Jeff Gatie
    Aug 19, 2002
    6,531
    15
    You'd hear it a lot less than if it was parked in the same room as you.
  8. Jeff Gatie
    Aug 19, 2002
    6,531
    15
  9. Wayne A. Pflughaupt
    Wayne A. Pflughaupt Well-Known Member
    Aug 5, 1999
    6,040
    17
    Katy, TX
    Wayne
    Jeremy,
    It’s pretty hard to make a prediction on how it will sound. Just try it and see. Naturally, you’ll want the door open when you’re using the system.
    Wayne A. Pflughaupt
  10. Wayne A. Pflughaupt
    Aug 5, 1999
    6,040
    17
    Katy, TX
    Wayne
    Jeremy,
    Wayne A. Pflughaupt
  11. Jeff Gatie
    Aug 19, 2002
    6,531
    15
    That's not what I got from Jeremy's post. He asked if being behind the door will affect the sound. Seems like he wants to hide it completely, even when in use.
  12. Jeff Gatie
    Aug 19, 2002
    6,531
    15
  13. Jeremy Deal
    Jeremy Deal Member
    Feb 4, 2004
    17
    Thanks for replies. I would probably wouldn't want to leave the door open for movies, but if I push comes to shove that's what I may have to do. I may give it a try, for shits and giggles anyway. I'll let you know what happens. Anybody else got any thoughts?
  14. Jeremy Deal
    Jeremy Deal Member
    Feb 4, 2004
    17
  15. ChuckRG
    ChuckRG Active Member
    Jan 21, 2003
    44
    Do you mean any thoughts beside trading in your wife for the more sympathetic variety??
  16. ChuckRG
    Jan 21, 2003
    44
  17. paul clipsel
    paul clipsel Well-Known Member
    May 31, 2004
    163
    Thats one tough wife. Mine is pretty tough about things she feels makes the place ugly. But she is not quite at the stage of put the sub in the closet. Thats a very tough level to beat. Chuckle and laugh as I may; I just can't imagine listening to my Hsu sub located in the closet.
    You can only try it in the closet, but I would not expect it to be the best place for producing low bass.
    PC
  18. paul clipsel
    May 31, 2004
    163
    PC
  19. Mike SJ
    Mike SJ Well-Known Member
    Nov 10, 2003
    718
    OK this is the extreeeeeeeme way to do things.
    TURN THE CLOSET INTO A SUB
    cut a hole in the door, mount the driver, make a real nice grill for the front so it is WAF acceptable.
    Basically turn your sub into an IB
  20. Mike SJ
    Nov 10, 2003
    718
