1. Guest,
Sub hookup help please
Discussion in 'Speakers' started by DavidAMennie, Jun 27, 2004.
  1. DavidAMennie
    DavidAMennie Well-Known Member
    Jan 9, 2004
    85
    Hi, I need advice/opinions please. My receiver is a Yamaha RX-V630. My sub is a Velodyne CT-120. My mains are Wharfedale 8.3's. Anyway, i've always had the receiver settings on "small", and run a sub cable out to the sub, using the receiver's crossover. Recently, I decided to try high-level connection. Running speaker wires out of my receiver to the sub, then from the sub to my mains. I swear it sounded better. I hate the fixed receiver crossover, as my mains are rated at 40hz-20khz. So, obviously, they can go lower than 90hz. And, it seems to sound better anyway with the subs crossover. So, I can't decide how I want to hook it up now. Also, the high-pass crossover on my sub is 80hz or 100hz. I had it at 80hz using high-level. And, the sub crossover was 80hz as well. Opinions?
    Dave
  2. ChuckRG
    ChuckRG Active Member
    Jan 21, 2003
    44
    If you like the way it sounds, why would you want anyone elses opinion?
  3. DavidAMennie
    Jan 9, 2004
    85
    I don't know, thanks.
