1. Guest,
Studio Canal (Europe) goes neutral by releasing first Blu-Rays
Discussion in 'Blu-ray and UHD' started by Dave_P., Feb 15, 2007.
  1. Dave_P.
    Dave_P. Well-Known Member
    May 20, 1999
    983
  2. Dan Hitchman
    Dan Hitchman Well-Known Member
    Jun 11, 1999
    2,714
    And there'll probably be speed up of some sort. Video and/or audio.
    Dan
  3. TonyD
    TonyD Who do we think I am?
    Dec 1, 1999
    16,851
    280
    Disney World and Universal Florida
    Tony D.
    i sure wish you guys would indicate in the title that you are referring to info outside of U.S. or reg 1
  4. Ali B
    Ali B Well-Known Member
    Oct 22, 2000
    276
    The Babel is just a repackaging of other regions Paramount release - perhaps it was stated in the HD release contract to do both?
  5. Fozziwig
    Fozziwig Well-Known Member
    Feb 10, 2007
    49
    4
    I believe all HD content (both formats) is encoded at 24 fps (23.97 to be exact).
    No speed-up to worry about with HD.
  6. Dave Mack
    Dave Mack Well-Known Member
    Jan 28, 2002
    4,670
    4
    Actually quite a few of the Studio Canal European HDdvd releases like Basic Instinct and First Blood has pitched up audio issues. What they think happened was they took a PAL audio transfer and digitally slowed it down by 4% to match the new HDdvd transfer. But the 1/2 step higher audio pitch remained.
    http://www.avsforum.com/avs-vb/showt...ighlight=pitch
  7. Fozziwig
    Feb 10, 2007
    49
    4
    So, a few titles are affected because of incompetence (or penny-pinching) at the transfer stage? In any event you are right that these errors would be carried over to both the HD DVD and Blu-ray editions - unless SC did corrected transfers for Blu-ray releases.
    It is correct that new transfers won't be affected because the frame rate for both HD formats is 24 fps. For example, 'Babel' from Studio Canal will be identical to the USA release in terms of audio pitch.
    Hopefully people have complained to SC and they will make efforts to use 24fps soundtracks to go with their 24fps picture.[​IMG]
  8. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,144
    242
    Cees Alons
  9. JulianK
    JulianK Well-Known Member
    Oct 3, 2000
    844
    Studio Canal, via their recently-acquired sales-and-distribution label Optimum, have something of a reputation here in the UK among DVD connoisseurs for penny-pinching and sub-standard SD transfers.
    I hope that anyone planning to pick up titles that are otherwise exclusive to one format or the other in the US will proceed with caution.
  10. Dave Mack
    Jan 28, 2002
    4,670
    4
    Is Studio canal also releasing a PAL SD version of these? If so, and they truly ARE penny pinchers, they might just make one audio transfer (for the SD which would be sped up..) and then just digitally slow it down for the HD and BD discs.
    Would suck but it's possible. Easier and cheaper to make one mix than 2...
