1. Guest,
Studio 100 vs Studio 40
Discussion in 'Archived Threads 2001-2004' started by Darrin M, Feb 19, 2003.
  1. Darrin M
    Darrin M Auditioning
    Dec 19, 2002
    11
    Hi all,
    I am sorry if this has been posted before but the search function seems to be down.
    I want to upgrade the fronts of my HT and have decided on the Studio 100's or the Studio 40's. I already have the Servo 15 and the Studio CC. My question is this: do I need to go with the 100's. My thinking is, if I understand this right, all of the bass will go to the sub so I wouldn't need the extra low range capabilities of the 100's. Price isn't really a concern just sound quality. I will be powering whatever speakers I get with my Yamaha RXV995 as a pre/pro and the Outlaw 770 or a set of Outlaw 200's (another post for another time) [​IMG]
    If someone has the search working any posts on this discussion would also help.
    Thanks for any input
  2. Martin Rendall
    Martin Rendall Screenwriter
    Dec 5, 2000
    1,047
    I have the 100's and the CC. It's my feeling that the transition between the mains and the center is not quite seamless. I would expect the 40's to do a better job, as they are functionally much closer to the CC. On the other hand, I could be totally wrong.
    The 100's also require a higher end amp to drive effectively, which may or may not be a factor for you. Depends on the receiver or amp you are/plan to use.
    The 100's are awesome speakers, but then reportedly, so are the 40's. If I were buying again, I really don't know what I would get. Sorry - I guess that's no help at all. :b
    Another thought: do you have surrounds yet? Cause 4 40's and a CC would make an excellent balanced system. Stands to reason.
    Martin.
  3. Dave Ma
    Dave Ma Stunt Coordinator
    Jan 17, 2003
    113
    I just listened to the 40's 60's and 100's. Since you have that Servo 15 the 100's are not needed. With that said I did not like the 40's whatsoever, to "BRIGHT", no bass. The 60's sound like the 100's but with less bass. Factor in the price of stands for the 40's and your at the price of the 60's, plus to me the 60's sound much better. I am going with the 60's. 20's 60's 100's Are my favorites.
    Listen for yourself.
    This might help even though it's not for the 100's
    http://www.avsforum.com/avs-vb/showt...hreadid=224448
  4. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,998
    Portland, OR
    Greg
    Before I got my 40s, I listened to the 100s quite extensively (Theta Cassablanca and Dreadnaught front end). Although the 100s have more extension, I felt the 40s were more controlled and musical. If you like (very) high-spls the 100s may be worthwhile (more dynamic impact). Go listen to both and decide for yourself...
  5. Matt Odegard
    Matt Odegard Stunt Coordinator
    Nov 5, 2002
    212
    I have 40's. The 60's were too short and didn't reach my ear level. Besides I love the look of my 40's on the nice stands there on, which were only $75. IMO a much better look, sound and they have quite a bit of bass, you'll be suprised. But your ears have to decide.
  6. DonJ
    DonJ Second Unit
    Mar 5, 2002
    293
    To put it plainly, you're going to be happy ethier way you go. I'm happy with my monitors for home theater, Paradigm make a good speaker all around. I'm using my HK 320 as a pre/pro and Anthem PVA 7 amp.
  7. Jim_Lan
    Jim_Lan Agent
    Nov 23, 2002
    33
    I agree that the 100's and the servo give you overlap, but if sound quality is the key I found the 100's to have a better midrange than the 60's. Was easy to hear in A/B testing.
  8. Darrin M
    Dec 19, 2002
    11
    Thanks everyone for your suggestions and advice. Currently my dealer has a sound room set up with the Servo 15 the Studio CC and the Studio 40 for fronts and the Studio ADPs for the two sets of rears. When I heard this setup I was blown away and was ready to go for it but then the dealer said "do you want to listen to the 100's?" I think because I am relatively new to this the 100's visual presence was what made them sound better to me. So I thought I should come back here to get more informed opinions. Again thank you very much, I think it's time to go demo some Studio 60's.[​IMG]
  9. MikeRP
    MikeRP Supporting Actor
    Aug 8, 2002
    514
    I disagree with what Dave said about the bass on the 40's. Remember to ask if your listening to speakers that are broken in. I had some loaner 40's while my pair in rosenut were on order and they were fabulous.
    Got the new ones and the bass was terrible. 3 weeks later the new speakers were great. They almost have too much bass now in my setup (3 months later). I have the receiver turned way down.
    So I think the bass response may be determined by the room setup.
    But the 40's are fabulous and I wouldn't consider the 60's because I wanted the speakers higher off the ground.
    Just my opinion. You won't go wrong with any of the studios.
    Mike
  10. Chas_T
    Chas_T Supporting Actor
    Jun 1, 2002
    758
    Darrin,
    I have both these speakers in my 5.1 system and the 40's and 100's have distinct characteristics.
    Some things to consider with the 100's is amplification, 2 channel music, size of room, footprint and children.
    As you know, the 100's need 200 watts minimum for reference volume as suggested by Paradigm. The 100's will play with less power, but my tests have shown with Parasound and Modial/Aragon amps, which range from 85 x 2 bi-amped to 125 watts, they lose something when pushed with less power.
    There are still audiophiles who enjoy listening to music with just the fronts and no sub. I can remember the days when subs were not even a part of a 2 channel system. That is one reason I bought the 100's as they provide fleixibility in this area.
    If you have a really large room, the 100's might have an advantage there as they have a bit of extra zap with their lower extension and reproduction. They shine when they are placed away from the wall with a wide distance between them. Also, the 100's can be pickey about placement.
    Speakers on stands with smaller children can be a bit precarious depending on where your listening room is, placement and the kids themselves. The 100's are like 109 pounds and not easy to tip over.
    The 40's are great speakers. I love the look when placed on speaker stands.
    Four of them create a balanced sound with the CC. For most homes and tastes, they are a fine choice. It would not surprise me if Paradigm sells more 40's then any other speaker in the Reference lineup.
    The 40's cost less, create a great look, have more flexibility to adjust the height with the an appropriate stand, are much, much easier to move and also do not take as much space as the 100's.
    As Mike has written, "You can't go wrong with any of the Studio's" if you like the Paradigm sound.
    Much luck,
    Charles
  11. Darrin M
    Dec 19, 2002
    11
    Chas_T,
    Good to know other listeners out there use the same setup I am currently considering. Can I assume that you use 40 for the rears? I was thinking about the Studio ADP's for the rears and eventually the sides (7.1). If I go with the 40's should I use them for rears instead? My room is approx. 15 x 16 x 7 1/2. If I am reading all of the specs properly the Outlaw model 200(one per channel) or the 770 will handle the requirements of either speaker choice. This equipment will be used for HT about 85% of the time.
  12. Martin Rendall
    Dec 5, 2000
    1,047
    Chas_T,
  13. Chas_T
    Jun 1, 2002
    758
    Martin
  14. Chas_T
    Jun 1, 2002
    758
    Darrin,
  15. Martin Rendall
    Dec 5, 2000
    1,047
    Hey Charles,
    Here's what I believe: an amplifier with a decent damping factor (which is a gross simplification of what's going on) is going to distort less with the 100's. The 100's have a wild squiggly impedence curve; they are very reactive. While you may not even need more than 50 or 100 watts (probably less, in fact) to achieve your listening volumes, you do need an amp which can handle stressful current draw changes. It just so happens that the higher quality amps which can do this (in the price ranges of the typical 100's buyer) also happen to be high power amps, with impressive ratings like 200Wpc or 300Wpc, or whatever.
    So, in summary, the better amps handle crazy varying impedence loads, and sound better with the 100's. They also happen to have high power specs. The one doesn't have to imply the other - it just happens to be the case that the two characteristics are commonly found together in amps. EDIT: Actually, they are related, so manufacturers of course design for both.
    Paradigm tech support and dealers will find it much easier to just say, "get lots of power" than to try to explain what impedence handling characteristics an amp has. So I would take their statements with a grain of salt.
    I also don't think that passively bi-amping is the an optimal method of feeding the 100's. I believe it to sacrifice distortion for additional volume. This is totally subjective on my part, so please, nobody take offence. If you test it out, you'll see that two 100Wpc amps biamped to a speaker will by 3dB louder than one 200Wpc amp not biamped.
    Bottom line: I think it's hard to draw definitive conclusions about what's going on without much more empirical testing. My statements can't be anything other than opinion.
    Martin.
  16. Chas_T
    Jun 1, 2002
    758
    Martin
