1. Guest,
SPL meter and banana connectors.
Discussion in 'Home Theater Projects' started by cabreau, Dec 16, 2003.
  1. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    I'm looking for a good, cheap, probably analog SPL meter, and some good but pretty cheap (gold) banana clips/connectors. Anyone have any recommendations?
  2. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,293
    506
    Since 2006
    Cameron Yee
    Most people go with the analog Radio Shack SPL meter. I've not seen any other mentioned or recommended. Runs about 30.00.
  3. Jack_TN
    Jack_TN Stunt Coordinator
    May 5, 2003
    88
    I've read that the analog RadioShack SPL meter has been discontinued. Is it still available anywhere? If not, is the RS digital SPL meter the next best choice or would you go with some other brand analog meter?
    I briefly looked at the manual for the RS digital model. I can understand that it might seem easier to watch a needle on a meter, but it looked like some of the features on the digital model, like peak hold or indicating when a particular reading is hit, would be handy. Set it for the target reading, say 75 db, and crank up the setting on your receiver until the indicator on the meter lights up.
    Jack
  4. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    That's why I'm hoping my EZ Set remote from H/K works as good as one of those. [​IMG]
  5. Cameron Yee
    May 9, 2002
    11,293
    506
    Since 2006
    Cameron Yee
    I would just ask your local RS store, then check eBay. I'm always under the impression RS stores don't keep much in stock (I think it's just the size of the stores in the malls) but every time I've asked about something they've been able to pull it out of the back. Floor space is lacking I guess.
    I've only heard a few vague complaints about the digital one not being as good for the purpose of calibration. Can't tell you why, maybe TOO accurate?
  6. ken-m
    ken-m Agent
    Dec 14, 2003
    33
    I HAVE THE DIGITAL RADIO SHACK MODEL AND IT IS VERY ACCURATE. MUCH BETTER THAN THE AUTO CALIBRATION IN MOST RECEIVERS.
  7. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    $50 bucks though...damn. Isn't there a cheaper one anywhere? [​IMG]
  8. Scott Merryfield
    Dec 16, 1998
    11,458
    658
    The analog SPL meter is no longer on Radio Shack's website. They do still list the digital SPL meter, selling for $50.
  9. Cameron Yee
    May 9, 2002
    11,293
    506
    Since 2006
    Cameron Yee
    There is currently a Radio Shack analog model on eBay, ending in the next day or so. The Craftsman would probably be just fine.
    I would definitely recommend using a calibration disc versus a receiver's internal test tones. By using a disc you are putting the player and its particular playback characteristics into the mix.
