1. Guest,
Sony sa-wm40 vs Veladyne VX10 Opinons
Discussion in 'Speakers' started by Frederick Scott, Feb 21, 2003.
  1. Frederick Scott
    Frederick Scott New Member
    Feb 21, 2003
    4
    I am in the market for a subwoofer in the $200 range. The Sony 12" sa-wm40 and velodyne vx10 are my 2 choices.
    Can anyone tell me if one is that much better then the other.
    I am leaning toward Sony because it is a 12" as opposed to the 10" veladyne.
    Scott
  2. Rob Rodier
    Rob Rodier Well-Known Member
    Jul 11, 2002
    538
    Velodyne makes a great subwoofer. I would go with them simply based on their name and rep. It also puts up respectable numbers. 36hz-120hz +/- 3db. Proably similar to the sony even though they quote a 20hz rating (which is at a ludicrous -10db)
    I have heard the sony, and while not bad, it leaves a lot to be desired. I have not heard the velodyne.
    Regardless, woofer size should not play a role in your decision.
    -rob
  3. Frederick Scott
    Feb 21, 2003
    4
    Thanks Rob,
    The reason I was concerned about size is that I have a very open split level house. The living room is sunk-in and open to the kitchen area and there are not a lot of sound absorbing materials in that area. The problem is listening later at night. Anything but very moterate levels disturb sleeping kids. I figured that a 12 would move more air for the same volume level. But again speaker quality and design probably have a lot more to say about tha than jusr woofer size.
    Scott
  4. steve nn
    steve nn Well-Known Member
    Jan 12, 2002
    2,420
    Frederick YGM.
  5. James Grasso
    James Grasso Active Member
    May 20, 2002
    39
    I currently have the sa-wm40 and just ordered a vx-10, so I'll put up a small review or something for everyone asking about this sub vs. the wm40 when I get it. Someone spilled a drink into my sony sub, but it looks like I'll be able to "fix" it after all, so I'm going to try both of them together and separate and see what the results are. I don't know too much about HT though, so anything I post is from a newbie opinion, FYI.
  6. Kevinkall
    Kevinkall Well-Known Member
    Mar 20, 2003
    331
    You should be able to find the Sony for well under $200 and don't forget the poly-fill mod...the difference is night and day.
