1. Guest,
Sony receiver to SpeakerCraft Big Bang amp help
Discussion in 'AV Receivers' started by drewihle, Jul 14, 2012.
  1. drewihle
    drewihle New Member
    Jul 14, 2012
    2
    I used a sony a/v receiver to use with my new SpeakerCraft big bang 8 channel amp. The amp is working and the signal moves through the equipment just fine, I just can't use the volume control on the receiver. At first I thought it was the receiver as it is older, so I purchased a new Sony receiver. Same issue. I'm completely baffled. Can someone tell me what I'm doing wrong?
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,041
    894
    Chicago-ish/NW Indiana
    Sam
    99%* of AVR...
    If you connect Zone 2/3/4(however many are applicable) via pre-out, the OTHER end has to have volume control.
    What model number AVR so we can read the manual for you.
    *Maybe 95%. I've had Yamaha, Panasonic(back when they were good...and cared), Onkyo/Integra and Marantz.
    None of the 7-odd AVR I've had that did Zone audio had volume control via the pre-out.
  3. drewihle
    drewihle New Member
    Jul 14, 2012
    2
    It is an STR-DH13- if I'm not mistaken. So I need to put some sort of volume control at the end of the series? How would I do that if the outputs to the speakers are on the amp.
  4. schan1269
    Jul 4, 2012
    17,041
    894
    Sam
    You buy either...
    A Speakercraft(or one of the dozens of other brands) "Multi-zone controller"...
    Or take the Big Bang back where you bought it and get this...
    http://www.amazon.com/Speakercraft-MZC-64-Multi-Zone-Amplifier-Controller/dp/B000RAEGOO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1342379441&sr=1-1&keywords=speakercraft+multi-zone+control
    Plus...how many of these you need...
    http://www.amazon.com/Speakercraft-MODE-Wireless-Keypad--White/dp/B0055NCBZY/ref=sr_1_5?s=electronics&ie=UTF8&qid=1342379581&sr=1-5&keywords=speakercraft+multi-zone+keypad
    Edit:
    The only two BB(8 channel) I see are an 835 and 865. They both have zone volume. If you want "further" control, you need individual controls in the room, which I'm not sure the BB series are capable of that...without "something" before it as a control...such as(one example of many, the "multi-zone controller")...
    http://www.amazon.com/Channel-Vision-A4603-Multi-Zone-Pre-Amplifier/dp/B0015ADGA0/ref=sr_1_4?s=electronics&ie=UTF8&qid=1342380257&sr=1-4&keywords=multi-zone+pre-amp
