1. Guest,
Small A/V Decoder/Sound Processor Available???
Discussion in 'AV Receivers' started by ElectronicHoby, Dec 1, 2009.
  1. ElectronicHoby
    Dec 1, 2009
    17
    I have a new laptop with HDMI out.
    My plan is to play BluRay and Dolby/DTS encoded videos. I built a few class T Tripath amps and would like to use them.
    My reasoning is such. First, the power specs for A/V Receivers is so misleading. The rating is for one channel being driven. So a receiver touting 120 watts each channel, may actually, under test be 50 or so with all 7 channels running.
    So, I have 3 TriPath true 100 watts per channel amps that are pretty small. I also know HDMI is the only way to get Dolby HD or DTS MA. So is there a small A/V processor that I can connect my HDMI out of my laptop too, then connect the output of the processor to my three amps (this will give me 6.1 at most).
    Hope I am explaining my intent clear enough.
    Thanks for anyones help in advance
  2. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    5,945
    30
    ManW
    Look out for the new Emotiva UMC-1:
    http://emotiva.com/umc1.shtm
    Also discussed in this occasionally revived thread:
    http://www.hometheaterforum.com/forum/thread/287688/emotiva-umc-1-av-pre-amp-comming-next-month
    AFAIK, no other quality, HD prepro comes close to this budget range.
    Your other alternative would be to just buy a lower end AVR and use it as a prepro (like some of us have been doing), especially if you're not looking for audiophile level performance. I currently just use a Yamaha 663 AVR for just that -- driving my old B&K 5-channel amp. IIRC, I paid somewhere in the $300-350 range maybe 1-1/2 years ago for the Yammy. If you only actually need M-PCM over HDMI, not actual decoding of the compressed HD formats, then you might have moderately more options at the low end -- maybe you can even pick up a lightly used Yamaha 661 for that instead.
    I may eventually upgrade to the Emotiva (or maybe something else), but for now, I'm quite satisfied w/ the Yammy AVR as a prepro.
    _Man_
  3. Rebecca135
    Rebecca135 Auditioning
    Dec 17, 2009
    Hi buddy, thanks for the information. Check out my site for sales coupon coupon codes cheers
  4. BillMike
    BillMike Auditioning
    Mar 22, 2010
    2
    I may eventually upgrade to the Emotiva (Cheap tiffany jewelry?), but for now, I'm quite satisfied w/ the Yammy AVR as a prepro.
  5. BasketNike
    BasketNike Auditioning
    Nov 16, 2010
