Bruce Morrison
- May 16, 2001
That's true - Blu-ray players observe region-coding for SD DVDs, although I understand at least one European company is now offering a Blu-ray player that will play Region 1 and Region 2 DVDs (I believe you have to specifically select the region via the remote each time, which sounds a slight pain).
It's worth remembering that there are also regions for Blu-ray but, just to confuse us, they are different from the regions for SD DVDs! It's not so significant from a technical viewpoint (unlike the PAL speed-up issue for SD, all BDs reproduce films at the correct speed!), but it may have some significance in terms of software choice and pricing, both of which will probably be better in the US than in the UK.
