1. Guest,
Simultaneous DVD-A and SACD hookup
Discussion in 'Archived Threads 2001-2004' started by Yumbo, Jan 7, 2003.
  1. Yumbo
    Yumbo Well-Known Member
    Sep 13, 1999
    2,243
    hi,
    I have an RP82 with DVD-A and am looking for a 2nd player with progressive scan AND A BUILT-IN SCREENSAVER (to protect plasma), and might as well come with SACD - any recommended players?
    since receivers only have 1 analog 6 channel input - is there a recommended way to hook up both?
    thanks
  2. Paul_Medenwaldt
    Paul_Medenwaldt Well-Known Member
    Feb 6, 2001
    649
    I also would like to find out if this is possible. I will be getting a SACD player later this year and I already have my DVD player hooked up to 6 analog inputs.
    Is there a switch out there?
    Paul
  3. Scott Merryfield
    Dec 16, 1998
    11,450
    651
  4. kevitra
    kevitra Well-Known Member
    Apr 24, 2002
    364
  5. Philip Hamm
    Philip Hamm Well-Known Member
    Jan 23, 1999
    6,888
    2
  6. John Kotches
    John Kotches Well-Known Member
    Mar 14, 2000
    2,636
    Philip,
    Yes you do. I use one of the switchers in my second system, and ordered all the cables I need from Parts Express for somewhere around $40 / 12 pair, including shipping.
  7. Craig_Kg
    Craig_Kg Well-Known Member
    Feb 25, 2002
    768
    Or get a Sony ES or QS receiver....
  8. KeithH
    KeithH Well-Known Member
    Mar 28, 2000
    9,427
    I use the Radio Shack switch boxes, and they are great. As for cables, it doesn't have to be that big a deal. If you are running separate DVD-Audio and SACD players into a receiver with two sets of multi-channel inputs, you need 6 pairs of cables. If you have separate components and use the Radio Shack switch boxes with a receiver with one set of multi-channel inputs, you need 9 pairs of cables. Unless you are using high-end cables, the extra three pairs shouldn't break the bank. I have separate DVD-Audio and SACD players and a receiver with one set of multi-channel inputs. I gladly bought the Radio Shack switch boxes for $30 and three more pairs of cables. That ran me a lot less than buying a new receiver like the Sony STR-DA4ES.
  9. Ron S
    Ron S Well-Known Member
    Aug 11, 2001
    76
    Or you *could* just connect the SACD player via two channel analog to the receiver, and reserve the DVD-A player for the multichannel inputs. Or vice-versa.
    You'd give up multichannel SACD with the first option. For my own tastes, I find I rarely listen to the multichannel portion of SACD's. The fidelity of the 2 channel output is so good, plus there are numerous 2 channel only SACD's.
    Multichannel makes more sense to me for DVD-A, as you can use the DVD's player's capabilities insofar as DD and DTS tracks.
    Just another option, YMMV.
