1. Guest,
Sherwood Newcastle 945 A/V Receiver- low volume
Discussion in 'AV Receivers' started by lilaceo, Jun 3, 2012.
  1. lilaceo
    lilaceo New Member
    Jun 3, 2012
    Hello,
    My name is Jose from Spain, I have also a 945 RDs receiver and last months it's happening to me the same.
    I solved by reseting the receiver.
    Under the "Input Selector" there is the place where using a clip you can reset it.
    Try it.
    I have arrived to the conclusion that inside the receiver it has a battery that trought the years is now uncharged and it doesn't work and when the receiver is completely switched off. It lost its memory.
    Try it.
