Sewell 5g wireless hd av transmitter help (1 Viewer)
crayphish
Kelly
Hello! I am having such difficulty with this set up. It is simple, from the laptop to the tv 7 feet across the room. The sound is fine. BUT, I can only see 2/3 of the picture transmitted from my laptop. The bottom third is a colorful mix of dancing pixels. Laptop has Windows 7 on it.....HP probook S....I know I am missing something simple. I have changed settings and changed them back again.
Can anyone give insight as to what setting I am missing?
Any help is truly appreciated.
Crayphish
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
Sorry for the delay in responding. Wireless can be tricky, wireless HDMI can be super tricky. I would recommend getting a cheap HDMI cable and using that to plug into the TV for troubleshooting purposes. If the picture looks good, then you know your PC is set correctly and its a problem with the wireless HDMI unit. If you still see the problem, then you know its the PC or display.
acinstallation715
