1. Guest,
Screen help
Discussion in 'Displays' started by Josh Stevens, Aug 5, 2003.
  1. Josh Stevens
    Josh Stevens Member
    Aug 4, 2003
    10
    Hi people, long time reader first time poster.
    I have just invested in my first projector and wanted to know a little bit more about screens.
    I have done a search through past threads for info on screens and drew a blank.
    I have ordered a HW-WALLSCR84 (Infocus Pull-Down Screen).
    I am wondering if this is a good screen.
    and also what are the screens made of?
    and what difference in picture different screens make?
    It is to go with a HP VP6110 (1500 Ansi Lumens, 2000:1 Contrast ratio) I wanted an X1 but unfortunately stock levels are not good on these and it would have taken nearly 2 months to arrive.
    Thanks in advance,
    Cheers,
    Josh
  2. Neil Joseph
    Neil Joseph Well-Known Member
    Jan 16, 1998
    8,341
    Neil Joseph
    Welcome Josh. I am not familiar with that particular model of screen, there are hundreds.
    A screen is equally important as the projector is. Once you decide on a projector then you must "match" it with an appropriate screen with a gain that will benefit not only the projector but the room it is placed in. Screens come in various gains from 4.0 and beyond. Too high a gain could yield hotspotting and too low a gain will result in a dim image.
    I would like to know what the real-life specs for the HP are just for curiousity... ie, when it is throwing out 1500 a.l. then what is the c.r. and to achieve the 2000:1 c.r., what is the brightness.
  3. Josh Stevens
    Josh Stevens Member
    Aug 4, 2003
    10
    Here are the specs, i cant post links yet as i am too new to the forum, perhaps you may be able to helop with my other threads too, "HELP!! am i expecting too much" and "Widescreen"
    specification
    brightness 1500 Peak ANSI Lumens
    contrast 2000:1
    resolution 800 x 600 True SVGA (1024x768 compressed)
    light source 250-watt UHP projector bulb
    colour bit depth 24 bit
    lens F/2.6, f=23.2 to 28.38 mm with manual zoom and manual focus
    zoom capability Optical
    image scaling 1.2:1 zoom
    projection distance Approximately 1.5 to 8 m
    projected image size 0.74 to 4.76 m (diagonal)
    keystone correction, projector +/- 7º (14º total) except 1080i/1035i
    power consumption 330 watts maximum
    power supply Input voltage 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
    tilt angle 10 degree with elevator foot
    remote control Wireless IR remote controller
    weight 3 kg
    dimensions (W x D x H) 308 x 238 x 95 mm
    connectivity
    I/O ports Input: 15-pin VGA input connector, YPbPr RCA jack (green/red/blue), video RCA jack (yellow), audio RCA jack (white/red), 3.5 mm stereo mini jack, S-video connector, UART mini-DIN 8-pin connector; output: B-type USB terminal for mouse port, 15-pin VGA output connector
    computer compatibility PC compatibility: 640 x 400 to 800 x 600; compressed: 1024 x 768; 1280 x 1024; Composite-Sync; Sync-on-Green; Interlace mode (C8514A)
    video compatibility S-video, composite, component, HDTV (up to 1080i)
    video format NTSC, NTSC443, PAL, PAL-M, PAL-N, SECAM
