Todd Stout
- Jul 13, 1999
Hello all,
I picked up a router a couple of weeks ago and now I need a few router bits to complete my Adire Kit-281 and Kit-81 speakers.
I was looking at the MLCS Woodworking site and I was about to order a 3/4" plunge cutting straight bit, a 1/4" spiral upcut, and a 1/4" radius roundover. I can use the 3/4" plunge cutting straight bit to create the driver recess for the 8" woofers but I'm not sure if I can use it for the tweeter recess. The hole for the tweeter is only 2" in diameter so I'm wondering if I might need a rabbeting bit of some sort for that. What would you guys suggest for the tweeter recess?
Thank you.
Thank you.
