Remote controlled lighting (1 Viewer)
bigshot
Stephen
I just set up a x10.com remote control lighting system in my theater in about 15 minutes. From my main viewing position I can now contol the dimmer on the overhead lights, turn two table lamps on and off and switch on the Xmas lights I use to find my way to the bathroom in the dark. I feel like Steven Spielberg!
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
Very nice. Is that RF based or IR based? Did you just use replacement wall switches for the overhead lights and dimmer modules for the table lamps? Were you able to use your existing universal remote?
bigshot
Stephen
It's Infrared, so I suppose you could use a universal remote. I'm using wall switches as the remote, they're flat and lay on a table nice. Easier to handle in the dark than a remote and I have three separate lights and a dimmer on it. It was a little bit confusing to figure out which modules I needed. Eventually I ended up with a wall dimmer, a transmitter and three appliance switch modules. The dimmer covered the overhead, two appliance switches covered two table lamps on the same button and the third button covered the Xmas lights I use for night lights.
acinstallation111
