1. Guest,
Receiver died
Discussion in 'AV Receivers' started by Vagabond, Aug 25, 2013.
  1. Vagabond
    Vagabond Active Member
    Aug 18, 2009
    33
    Is it worth it to fix or even try to figure out and replace a part?
    My Onkyo receiver (HT-R500) up and died. It cut off and i was not fast enough and the kids turned it back on. I saw a small blue flash and then no more turning on.
    It an older model easy enough to figure out what part? fix it or just suck it up and get a new one. If i don't fix it what are the options feel bad just throwing it away.
    Txs
    Eric
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,041
    894
    Chicago-ish/NW Indiana
    Sam
    Usually a blue flash means a cap blew. Usually when a cap blows it chars everything around it. Wouldn't hurt to leave it unplugged for 24hrs, remove the cover.
    If a cap blew and didn't char its board(more than likely the power supply), sure.
    I wouldn't pay to fix it though. Only if you are good with soldering.
  3. Vagabond
    Aug 18, 2009
    33
    thanks ill check it out. but looks like I will be getting a new one.
