1. Guest,
Question on ohms
Discussion in 'Beginners, General Questions' started by Marc Grennan, Jun 7, 2013.
  1. Marc Grennan
    Marc Grennan Member
    Jun 7, 2013
    5
    I am fairly new to everyone, and I came across a fairly cheap Sony receiver and had a question about it, so here I am.
    It's the STR-DH740 and it says " 7.2-channel, 1015W (145W x 7 @ 6 ohms " which is fine and dandy but the speakers I am looking at are 8 ohms. Will the receiver be able to run them or do I need to look for either new speakers/receiver?
    Thanks in advance..
  2. Al.Anderson
    Al.Anderson Well-Known Member
    Jul 2, 2002
    2,465
    56
    Al
    As long as the receiver/amp can handle *less* than what the speakers are rated at, everything is good. So the receiver can handle 6 ohms, yours are 8 - you're good. Even when the "equation" comes out bad there's some give, as long as you don't crank the amp. The worst case is when the receiver is rated for 8 ohms and the speakers are rated at 4.
    By the way, the spec page says is has 4 ohm switching, but I don't see that in the manual. Not that you asked, but I'm also not a fan of Sony receivers; you can probably do better for $300. (Not that this one is a terrible choice.)
  3. FoxyMulder
    FoxyMulder 映画ファン
    Sep 14, 2009
    5,236
    1,612
    Scotland
    Malcolm
    Don't fall for the marketing BS, they have inflated the wattage numbers there and that's why they say at 6 Ohms as they can put that higher number, it's also probably with 2 channels driven and not all 7, to answer your question though, it will work fine with your speakers.
    You can buy it from Amazon with some freebies thrown in at the same price.
    http://www.amazon.com/Sony-STR-DH740-Channel-Receiver-Protector/dp/B00CIYHQ08/ref=sr_1_4?ie=UTF8&qid=1370603907&sr=8-4&keywords=STR-DH740
    sean1976 likes this.
  4. Marc Grennan
    Marc Grennan Member
    Jun 7, 2013
    5
    I appreciate both of your responses! I was looking through some of the other posts and found the Denon AVR1613 and I know that Denon makes some solid receivers. So I think that I am just going to go with that one.
  5. gene c
    gene c Well-Known Member
    Aug 5, 2003
    5,838
    46
    Bay area, Ca
    Gene
    The 1613 is a good choice.
    What speakers were you looking at?
  6. Marc Grennan
    Marc Grennan Member
    Jun 7, 2013
    5
    I was looking at the Klipsch KB-15's but now I have been checking out the Yamaha NS-333's since they're 6 ohms
  7. Al.Anderson
    Jul 2, 2002
    2,465
    56
    Al
    It doesn't make any sense to buy speakers based on their ohm spec unless you have a receiver that won't play that low. In this case the Klipsch's are 8 ohms, and are therefore MORE flexible for use with other receivers. It's best to audition and purchase based on sound preference, my next choice would be looks; but all else being equal buy the higher ohm speaker.
  8. Marc Grennan
    Marc Grennan Member
    Jun 7, 2013
    5
    Alright I take it that 8 ohms is the standard?
  9. FoxyMulder
    FoxyMulder 映画ファン
    Sep 14, 2009
    5,236
    1,612
    Scotland
    Malcolm
    For speakers and if going for 8 Ohm then look for a high sensitivity rating, look at the tech specs, something like 88db or higher as just one example as this means the speaker will be easier to drive than one rated at 84db, Ohm ratings never tell the whole story, speakers will often drop, for a small time, all the way down to 2 or even 1 Ohm at some point and some of the frequency range, the majority of well made AV receivers handle this just fine, nothing wrong with getting a good 6 Ohm speaker, my surrounds are 6 Ohm rated and work great with my Yamaha AV Receiver, i leave at 8 Ohm switch as putting down to 4 Ohm in the receiver can degrade sound quality, there are countless arguments about this and not everyone agrees.
    Don't worry about things like power handling or watts, modern speakers and AV receivers work just fine with each other, just look for a good sensitivity rating, 6 or 8 Ohm speakers will be just fine unless your AV Receiver is very poor.
    The Denon you are buying will handle 6 or 8 Ohm speakers.
  10. Al.Anderson
    Jul 2, 2002
    2,465
    56
    Al
    No so much "standard" as most common.
    Just to be clear, there's nothing wrong with 6 ohm for the Denon 1613. But you had said you were picking the Yamaha's *because* they were 6 ohm. That's what I was objecting to.
    Also, 映画ファン has a good point, other than actual sound preference, sensitivity is a valid consideration if you are concerned with loudness. Anything over 88-90 is good.
  11. Marc Grennan
    Marc Grennan Member
    Jun 7, 2013
    5
    Well what I am going for right now is just a 2.1 setup, cause I just rent a room in a house and with my bed and desk in there, it's not enough room for a full setup such as 5.1. I want speakers that can handle some quality highs and quality lows. I am not entirely sure what to look for when it comes to speakers haha... My budget for the receiver and speakers is roughly $800. I chose the Yamaha's because I found them on a website for $150 and thought it was a steal however I am not entirely dead set on what I am getting.
    I've looked that the Yamahas and I think they look good, but I had the chance to hear some RB-51's from Klipsch and was amazed by them, they sounded really good but they cost $300.
  12. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,038
    894
    Chicago-ish/NW Indiana
    Sam
    Buy your speakers correctly and you'll have them 50+ years.So 30 years from now...going to remember you spent $300 and not $150?
  13. mccambley
    mccambley Well-Known Member
    Jun 10, 2008
    635
    2
    Casey
