1. Guest,
question on installation
Discussion in 'Archived Threads 2001-2004' started by Michael Botvinick, Dec 27, 2001.
  1. Michael Botvinick
    Michael Botvinick Well-Known Member
    Sep 13, 2001
    104
    Gang,
    I have Dish Network for many years. The wife and I just bought a new house that is being built. When I move I can either stay with Dish or go to other. The questions are:
    a) do I switch
    b) How should I prewire for the Dish? There will already be coax in every room in the house with a central box located under the stairs. A local guy recomended that I run 6 seperate cables to the future location of the dish so I can be ready for HDTV. Does this sound correct?
    I apreciate any advise you can give me.
    Michael
    mbotvinick@trimedyne.com
  2. JohnMW
    JohnMW Well-Known Member
    Dec 1, 2000
    283
    I have DirecTV and use the Hughes E86 w/ elliptical dual LNB dish and HD signals are passed to my 16:9 HDTV with only 1 coax line. My second coax line allows the TV's in my other 2 bedrooms to watch the same channel since I only have a single receiver.
    The other 5 runs of caox will allow independent receivers, but you will need a 6 way multiswitch I suppose. How many rooms need to have a TV? Do you want separate receivers?
  3. Michael Botvinick
    Sep 13, 2001
    104
    Thanks John,
    I do not see my wife and I ever having more than two TVs on at the same time. In fact we only own two tvs. Therefore I will need two recievers. But only one TV is HDTV ready. From your HDTV dish to your receiver you only have one line runing (one line for each of your receivers making two total)??
    If so Then I only need two lines form the Dish. I thought more lines wee needed for the HDTV signal. Therefore I will not worry about running the lines until I order the dish. Are you happy with Direct TV? I heard they have horrible customer service. Dish Network has been OK for the past 5 years for me. But I can switch. How much was your Hughes E86 receiver? And is that all you need to gain access to the signal?
    Michael
  4. JohnMW
    Dec 1, 2000
    283
    I just signed up w/ DirecTV a few weeks ago, and my experience on the phone (twice) was pleasant.
    I have one receiver. The coax line from the dish on the roof goes thru the attic, to my receiver (HDTV), and another coax from the receiver goes to a splitter in the attic and to the other 2 rooms.
    I gave 700.00 + tax for the Hughes E86 HDTV receiver, Dual LNB Elliptical dish, plus setup and installation.
  5. Robert_J
    Robert_J Well-Known Member
    Aug 22, 2000
    8,264
    46
    Mississippi
