1. Guest,
PS3 Audio dropouts?
Discussion in 'Playback Devices' started by Scott Burke, Jan 28, 2013.
  1. Scott Burke
    Scott Burke Well-Known Member
    Nov 27, 2000
    463
    30
    United States
    Scott B.
    I have a PS3 sending the audio through an optical cable to my Denon AVR-1800. I had this problem before and switched the optical cable to the other optical input on the receiver, and the problem went away. No I was getting sound cutting in and out. I checked each connection on the cable, and all seemed to be well. Then I tugged on the cord to make sure it wasn't bent, and that cleared up the problem for about 2 minutes. Tonight, it was cutting out so much that I switched back to optical input 1 to see if that would work, but I don't get any sound from there. How do I check which component it is? Is it the reciever, PS3, or the cable itself? What would cause said audio dropouts. Any help would be appreciated.:huh:
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,036
    894
    Chicago-ish/NW Indiana
    Sam
    Considering how cheap(and I mean made...not price) toslink are...I'd try another one. Yes, they go bad.
  3. Scott Burke
    Nov 27, 2000
    463
    30
    United States
    Scott B.
    I will try that, thanks!
  4. Scott Burke
    Nov 27, 2000
    463
    30
    United States
    Scott B.
    That was the problem! Thanks!
