1. Guest,
Projector distance??
Discussion in 'Displays' started by TonyWright, Aug 23, 2005.
  1. TonyWright
    TonyWright Well-Known Member
    Jan 25, 2004
    272
    I am building a new theater room and I plan to use the BenQ PE7700 (unless someone can advise me otherwise [​IMG]). The room will be 14 x 16 and the screen will be one of the short walls at the end of the room. This gives me 16 feet of area with which to mount the projector.
    I am curious as to how far back is recommended for a 100 inch screen. Also I am cusious as to whether a 100 inch screen will be too big on one of the 14 foot walls in that room. Finally, I was planning on using the 1.78:1 aspect ratio for the screen, but I am unsure as to whether this is the best choice.
    Your thoughts and suggestions would be most welcome.
    Thanks very much for your time.
    Tony
  2. Kevin_F
    Kevin_F Well-Known Member
    Dec 1, 2004
    246
    If you check out Projector Central it should answer most of your questions.
    Good luck
