1. Guest,
Polk FXI A4 - rear placement (odd shape?)
Discussion in 'Speakers' started by erew99, Aug 6, 2013.
  1. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    Hi all,
    Looking at upgrading some Monitor 30 speakers I use for my rear speakers in my 5.1 setup.
    I'm looking for something that will really fill the room nicely. I like the 30s, but I don't think they really fill my room. They're loud, but I have to have them pointing right at me...
    I was looking into some replacements, and found the FXI A4. Supposedly these are better suited to fill a room.
    Room = 10 x 19.
    My question is, how do I place these? They have three sides to them, not 4.... What is confusing me is that you mount the flat side to the wall... and the other 2 sides have tweeter/woofers.
    Here's a link to the picture/description
    http://www.polkaudio.com/products/fxia4
    This might help to understand my room.
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,042
    894
    Chicago-ish/NW Indiana
    Sam
    The bottom of your drawing...Open, or a wall?
  3. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    UPDATED DRAWING:
    Left - full wall = 2' long.
  4. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    Your front 60 are too close together.Since you oriented the room wide, not long, bi/di-pole won't work.Can you hang the 30s from the ceiling? Across from each other is your only option with the room layout.
  5. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    The 60s (actually 50s...) are about 6' away from each other.
    Okay- so my only option really is to keep the 30s? My ceilings are like 14' in this room....
  6. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    14 feet, even better. Wider sound dispersion. Your room is 10. You sit, what 9 feet?Front channel should be 9 feet.
  7. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    Front channel around 7-8'.
    I don't want to mount anything on the ceiling for a few reasons - 1: running the wires... 2: the wife... :)
    So it is fair to say the A4s, aren't going to benefit me in any way, right? I should stick w/ the m30?
  8. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    Didn't mean ceiling. Up the wall around 10-12 feet.CorrectYes
  9. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    I see. I have them mounted currently - about 6' high. I could move them up, but won't I lose the effects? I mean shouldn't they be about ear level when sitting?
    In the future when I want to upgrade- is there something I should look for?
  10. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    Ear level would have been 4-ish feet. And assumes a proper speaker placement.You chose to do the room wide, not long, ergo...you threw proper placement out the window.Moving them up the wall, angled at opposite ends of the front of the couch gives them a chance at proper coverage.
  11. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    I'm not sure I understand.
    I can move them up to say 10'... But not 100% sure I understand what you mean about angling them.
  12. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    also the ceilings are vaulted... from 8' to 12'. Not sure if this matters.
  13. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    By the way, the 4/5 speakers should have 25-30 degrees to your rear. Not straight out.I will add to the sentiment, if your AVR supports height/width...utilize it.
  14. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    My AVR = Sony STRDH520 (7.1).
    I can't really move the speakers around too much in this room.
    I'm not really sure what the best option for me is... I could add another 2 speakers to complete the 7.1.
    I have two unused Polk OWM3 speakers. I was originally thinking I could mount the directly over the couch (main seating area) pointing downward...
    The other option would be to use these as front high speakers.
  15. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    The AVR does have IIz.Swap the 300 to the front if you want.
  16. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    I don't usually use any processing, but would you recommend using it?
    I'm not sure the best way to move forward.
  17. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    You don't have the layout for 7.1.You do for height and width, but your AVR only gives you the choice of height.I use both and another thread responder said to try it.What's the harm...?
  18. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    Confused- what other thread responder...
    And what 300 and what front?
  19. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    My bad, had thread thread confused with one like it yesterday. Anyway, you have IIz...
  20. erew99
    erew99 Second Unit
    Sep 5, 2006
    354
    19
    Guy
    Okay, so in order to use the front highs, I must use llz?
    I always leave the receive set to AFD AUTO... so I'm not really sure how or what I need to do in order to get the front highs.
