1. Guest,
Pls educate on speakers in general.
Discussion in 'Speakers' started by chun howe, Apr 28, 2003.
  1. chun howe
    chun howe Well-Known Member
    Apr 18, 2003
    119
    i am currently on my way to building a HT. thanks to this web[​IMG]
    i need some education on speakers. no specific brand just plain simple/in general.
    1. is lighter built drivers better than heavier ones?
    2. i was told by sales person that speaker companies that build thier own driver/cone are a better speakers.
    3. people like to use terms like warm, neutral, laid back, etc on speakers, what is it actually refering too?
    4. what type of speakers (floor/bookshelf) would be appropriate for living hall (14'x11')
  2. Martice
    Martice Well-Known Member
    Jan 20, 2001
    1,092
    H Chun. Welcome to the forum. See the below link and in the search bar enter "speakers". You'll find various articles on speakers and such.
    Good Luck and come back with any other questions.
    LINK
  3. chun howe
    Apr 18, 2003
    119
    thanks Martice, the site is very informative.
  4. Martice
    Jan 20, 2001
    1,092
    Hi Chun. No problem. If you put in the search box "Speaker Articles" it will stick to various articles relating to speakers in general and not speaker brands and such.
    This search will give you exactly what you are looking for.
  5. Arup
    Arup Well-Known Member
    Apr 27, 2003
    103
    Hi Chun,
    Auditioning is very important especially with your choice of music. A speaker has to be as neutral as possible. Stay away from terms like punchy, bright, musical etc. and see if what goes in comes out exactly as you expect.
  6. chun howe
    Apr 18, 2003
    119
    thanks for the tip Arup.
    i am new and learning and about to open up a can of worms[​IMG]
    how do you know it's neutral?
    i was told that i should bring along my favorite CD for audition....which brings me a question. if i haven't had experienced good speakers how am i going to know now it sounded good or bad on audition?
    to my understanding punchy would be a lot of cluttered bass.
    boomy sound. is that right? bright would be lots of treble. lots of sssssss.... sound..right/wrong??? and what's musical then?
    currently i bought home a set of KEF Q1 bookshelf speakers for home auditon. it sounded good (better than my 4.1 Klipsch that runs off my computer) i auditioned Energy Connoissuer C-3, NHT SB3, paradigm studio 80 at the shop. by far i love studio the most. but that's out of my budget. NHT SB3 is my second choice.
    Arup: what are your speakers? any suggestion? my living hall is only 14" x 11" two walls.
  7. Arup
    Apr 27, 2003
    103
    chun,
    I use Yamaha NS-300 as they seemed to be the most neutral. I have gone through various speakers like Martin Logan, dbx, JBl L7 etc.
    My brother is a musician and I took his friends along to audition and found the Yamaha to be the best. I also have Yamaha's legendary NS-1000x which was used as a monitor by Danish Boradcasting Corporation and several prominent studios around the world.
    Give the Yamaha NS-4HX, NS-8HX, NS-100, NS-300 an audition along with speakers from Magnepan, Canton, MB Quart and Sonus Farber. The Yamaha NS-300 speakers use silk dome tweeters which sound generaly better for music and is less tiring to listen to than metal domed ones. Dont go for speakers with massive woofers. Leave that job to the subs. You can mail me if you need more advice.
  8. Rich Malloy
    Rich Malloy Well-Known Member
    Apr 9, 2000
    3,999
  9. FrantzM
    FrantzM Well-Known Member
    Feb 9, 2003
    69
    Chun
    The goal of Hi-Fi should be a perfect replica of the original performance. In other words if it is a guitar playing then the system (Everything i-e CD + Amplifier + Cables + Speakers) should reproduce the guitar that was recorded. This is the ideal what we will call with apologies to a magazine I respect, the Absolute Sound (by the way the name of the magazine), the absolute reference. This of course never accomplished. What you want to do is to find the component in this particular occurrence a speaker that reproduces the sound of real music as well as possible. Not an easy task and not easily achieved either.
    A speaker should be like the postal service, it just delivers the goods the way they are, good or bad... A truly neutral speaker should do that. There is of course no neutral speaker and they add some things or subtract others and present the sound of the event in a different manner. Some grossly change the whole music and some do it very subtly. You should look for speakers that change the original as subtly as possible
    Like many things Hi-Fi. There is a matter of taste. What a speaker add or subtract may be or not to your liking. This is the reason why you audition with a favorite CD. I recommend that you go out and hear UNAMPLIFED music live in a reasonably good place. Familiarize yourself with the way some instruments sound and purchase a well recorded CD of a piece you like with if possible un-amplified music and human voices. I could recommend you some brands, Reference Recordings, Chesky, Telarc, Delos, Harmonia Mundi come to my mind but there are other and I can tell you for example if you are a fan of Dire Straits, their CDs on a great neutral system capable of high SPL sound like the real thing...
    GO and listen to a variety of speakers and decide which ones reproduces the real thing . it takes a while . Do not rush. The enjoyment of music is well worth it.
    Frantz
    Port-au-Prince, Haiti
    P.S.
  10. chun howe
    Apr 18, 2003
    119
    thanks Rich Malloy & FrantzM for the inputs.
    as an entry level me, it's getting more and more difficult to choose the right speaker for my taste.
    i did some research and i want a bipole/dipole rear surround speakers, and i found energy connoisseur c-r1, wharfedale wh2, axiom qs4.
    is there any other good brand speakers offer bipole/dipole?
    i don't like wharfedale it's bcos it's diamond 8.3 (front) is a 6 ohm impedence speakers. it would be taxing for my pionner vsx-d711 amp to play it. anyone with diamond 8.3 having problems using 8 ohm amp? and is kevlar driver any better than the poly type driver?
    i usually see AL or metal tweeter.
