1. Guest,
Phase control on subwoofers...
Discussion in 'Speakers' started by cabreau, Jan 6, 2004.
  1. cabreau
    cabreau Well-Known Member
    Dec 1, 2003
    322
    Can someone explain to me exactly how and why to set the phase control on a subwoofer? Right now I turned my sub facing the same way as my fronts and set it up against the wall. I left it on 0 degrees and it seems to sound ok...but I want to make sure that it how it is supposed to be setup...plus I just want to know what the hell it does!!! LOL. There was no explanation of it in the manual and I can't find anything online. Helpful links or posts would be greatly appreciated. I have a Paradigm PW-2200, if it matters.
    Thanks in advance.
  2. Chris A H
    Chris A H Well-Known Member
    May 10, 2002
    172
    From another post on this site:
    Worked great for me!
  3. John S
    John S Well-Known Member
    Nov 4, 2003
    5,460
    The more casual way to figure it out, is set it the way it sounds best. If it makes no difference, choose normal phase.
  4. cabreau
    Dec 1, 2003
    322
    Where do I get a sinewave test tone? :S
  5. John Doh
    John Doh Well-Known Member
    Jun 24, 2003
    199
    I'll add to the original question with one of my own... If you have your other speakers set to "Small", does the subwoofer phase function even come into play?
  6. cabreau
    Dec 1, 2003
    322
    I can answer that one...YES. All of my speakers are set to small...when I alter the phase setting the bass changes, almost as if it waits 50 milliseconds or so to do anything...almost as if it's trailing behind the rest of the sound.
  7. John Doh
    Jun 24, 2003
    199
    The reason I ask is when I received my SVS PB1-ISD the other day, during calibration using the Avia disc (all other speakers set to small) when running the phase tests and adjustng the phase knob on the SVS, the SPL meter reading did not change whether the phase was at 0 degrees, or 180 degrees. I, nor the meter heard any difference. Interesting...
  8. Lewis Besze
    Lewis Besze Well-Known Member
    Jul 28, 1999
    3,134
    The quote of Wayne's posts sums it up well.Also as a "rule of thumb" if the sub is along the wall of the mains,and relativelly close the pahase should be the same as the mains[0].Driver orientation has no bearing on this,only the placement of the enclosure.If a sub has variable controll for the phase,then yes you need the testones,and experiment to fine tune it.
    You can download testones from this site here:
    http://members.tripod.com/~terrycthe...um/page12.html
  9. Keith M.
    Keith M. Well-Known Member
    Apr 1, 1999
    489
    another method which I find easier is to reverse the polarity of the two main speakers, run a test tone at or near the lfe crossover setting of your receiver and slowly adjust the the subs phase dial until the LEAST amount of bass is heard from the listening postion.
    After this test, remember to put the mains polarity back to normal.
    I find it easier to detect a loss in lfe than a gain...
