1. Guest,
PE250 amp w/ bass boost
Discussion in 'Home Theater Projects' started by JoelTW, Apr 9, 2003.
  1. JoelTW
    JoelTW Stunt Coordinator
    Apr 1, 2003
    110
    Comments about bass boost w/ Shiva? Good, bad?
    [edit] Vented, ~140L, 4" flared port tuned to (23Hz I think?)
    TIA [​IMG]
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,952
    Stock boost is at 30Hz I believe. Bad.
    That big a box you'd want to tune lower. Change your mind about the EBS?
  3. David Lorenzo
    David Lorenzo Stunt Coordinator
    Dec 12, 2002
    198
    Hi Joel. Did you use the whole length of the tube for the Precision Port? You should have a lower tuning if you did. Around ~18 hz I believe.
  4. JoelTW
    Apr 1, 2003
    110
    I don't get the port until tomorrow. [​IMG] I'll try it with the whole port length...
    Also, I saw some pictures of a DVC sub with wiring the 2nd voice coil in reverse (series?)...Do I need to wire the 2nd voice coil?
  5. JoelTW
    Apr 1, 2003
    110
    what do I enter as the "Series Resistance" in WinISD pro
    here I took a screenshot... It says with only 150 W and 4 ohm it will be at its maximum excursion... or am i doing this wrong [​IMG]
    [​IMG]
  6. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    877
    The series resistance is NOT the resistance of the woofer. Its the resistance of the wire and terminals and connections along the way between the amp and the woofer.
    WinISD Pro puts an initial value of 0.1 ohm and that's a pretty good guess. 4 ohms is nowhere close and its messing up your sims. With 140L, 17 inch (effective) port length (18.5Hz tune) and 0.1 ohms series my sim reaches Xmax with about 220 watts at the highest excursion point above tuning - about 28Hz.
  7. JoelTW
    Apr 1, 2003
    110
    haha, ok, thanks a lot [​IMG]
    anyone know how quickly adire ships? I might order the driver soon [​IMG]
