1. Guest,
Optical Cable for Htr 5550
Discussion in 'Beginners, General Questions' started by midapo, Dec 29, 2007.
  1. midapo
    midapo Member
    Dec 11, 2006
    10
    I am hooking up a Toshiba HD DVD player to this unit. My hdmi cable will go straight to my projector, as there is no hdmi input on my receiver. I have been using a digital coax for my audio, but there is no digital coax output on the dvd player. It has an optical out which i plan to use.
    Question: The optical input on the receiver is not a regular size input. I believe it is a mini. On monoprice they have this cable: Toslink to Mini M/M OD:5.0mm. It descibes it as mostly used with laptops. Is this what I need? I have looked all through my receiver users guide and I cannot find what kind of input it is. Thanks
  2. Bob McElfresh
    Bob McElfresh Well-Known Member
    May 22, 1999
    5,183
    I did not think Yamaha had mini optical connectors. Esp for the HTR series. They try to be very generic/compatible.
    While you can save 5-15 dollars buying from monoprice, get a generic/cheap toslink cable from a local store and see if it works. I suspect it is an ordinary optical input on the receiver.
  3. midapo
    midapo Member
    Dec 11, 2006
    10
    I have tried a regular optical cable in the past and it was too big. that is why I went with the digital coax.
  4. midapo
    midapo Member
    Dec 11, 2006
    10
    I just wanted to post again and tell everyone that I am an idiot! [​IMG]
    I have built this system from the ground up, wires runing through the attic, underneath the floor, flush mount floor boxes, projector, screen, speaker placement, etc. People tell me it is the best sound they have ever heard. But I am not smart enough to take the little plastic protector off the end of the optical cable! IDIOT! I hope this saves someone else the embarrassment!
  5. JustinCleveland
    JustinCleveland Well-Known Member
    Dec 23, 2002
    2,059
    Madison, WI
    Justin Cleveland
    I was going to say, I have/had that receiver, and the Optical audio plugs worked just fine. [​IMG]
    Enjoy!
