1. Guest,
ONKYO S590- humming noise only during surround sound
Discussion in 'Speakers' started by johnHW, Jul 1, 2006.
  1. johnHW
    johnHW Auditioning
    Jun 30, 2006
    2
    Hey guys. This is my first post here. I'm not a 100% this is where I am suppose to post about this topic but i'm having some sound problems. I just purchased an onkyo s590. when i turn on the surround sound i get this very annoying humming noise. If i turn it back to stereo the noise is gone. I unplugged all the electronics one by one and it only disappears when the electronic from where the sound is coming from is unplugged (either the dvd or the cable box). I am using a optical cable from dayton. i am changed the orginal wires to 16 gauge wires from radio shack. all the wires are plugged into the spring clamps.
    can anyone help?!
  2. johnHW
    johnHW Auditioning
    Jun 30, 2006
    2
    ok.. so i unplugges all the speakers and it seems to only happen when the center speaker is plugged in. i tried to change the wires as well as move it to a different location. as long as it is plugged in it makes the noise. can anyone help?
  3. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
    JohnHW,
    That is indeed odd. I can't say I've ever heard of the center channel being the culprit. I'm not sure how it can be... Are you sure the wires are connected in such a way that they don't touch other bare speaker wires (at the terminals)? Does the center channel's wiring have a run that avoids excessive contact with electronic devices (I'm grasping at straws here). And, let's go for the usual culprit, have you tried unplugging (connections and power) the cable box?
    -Robb
  4. Bill_Br
    Bill_Br Agent
    Jul 3, 2006
    33
    John,
    I purchased an HT-S590 a few days ago and have been having the exact same problem as you. I am also using a heavier-gauge wire, and the hum stops when I disconnect the center speaker.
    On another audio forum where people have reported the same problem, I learned two things: First, some users started having the problem AFTER they switched from the supplied speaker wires to heavier gauge ones. I had the problem from the start because I used heavier wire from the beginning. I haven't tried switching to the supplied wire.
    Secondly, a couple of people wrote that the hum goes away if you loosen a turn or two the two screws on the back of the receiver where the speaker push terminals are. I know a suggestion like that sounds like I have a loose screw, but I tried it and, by golly, it works.
    Because Circuit City says that they are willing to swap out my unit for a new one, I'm going to do that, because even though the hum went away after I loosened the screws, the sound doesn't seem quite as crisp as it is when the unit is set on "Stereo."
    Good luck,
    Bill
  5. PhilMays
    PhilMays Stunt Coordinator
    Jul 1, 2003
    53
    I had a very similar problem that manifested through the center speaker. My problem is in the TV ground. If I move the center wire further from the TV the hum is reduced. Likewise, if I move the TV further out from the wall the humm reduces. I just purchased a Belkin Power Conditioner that helped some as well.
    For reference, I am using a Yamaha RX-Z1, Klipsch RC-7, Biwired with Kimber TC 8 cable, and a Pioneer RPTV.
    I hope this helps you some...it's very annoying
    Phil
  6. Bill_Br
    Bill_Br Agent
    Jul 3, 2006
    33
    Following up on my previous msg ("I purchased an HT-S590 a few days ago...."), Circuit city replaced my HT-S590 with a new unit, and that seems to have solved the humming problem. So, it's not an issue with every unit.
    Bill
