1. Guest,
Onkyo or Integra receiver?
Discussion in 'AV Receivers' started by Adams3177w, Oct 11, 2010.
  1. Adams3177w
    Adams3177w New Member
    Jun 15, 2010
    4
    I have recently narrowed down my selection for a receiver, I've been looking at the Integra 80.2 and the Onkyo TX-NR 5008 I know these receivers have similar qualities. I get a 10 percent disscount if I ordered it from a well known electronics retailer. Which one should I go with?
  2. Ed Moxley
    Ed Moxley Well-Known Member
    May 25, 2003
    2,701
    Eastern NC
    Ed
    Whichever one you're comfortable with. Integra is Onkyo's higher end stuff, so basically, you're getting Onkyo either way you go. I like Onkyo a lot. You can see in my signature that I use Onkyo too. You should be very happy with either.
    Good luck!
  3. Philip Hamm
    Philip Hamm Well-Known Member
    Jan 23, 1999
    6,888
    2
    I've had great experience with Onkyo's Integra brand over the years. I still use an old DTR-7 in my main home theater room.
  4. DavidZ
    DavidZ Member
    Nov 20, 2001
    6
    They are basically the same receiver. The features are almost identical. The warranty on the integra is 3 years and on the onkyo is 2. I would look at the price and the slight difference in the feature set. I ended up with the nr 5008
  5. DavidZ
    DavidZ Member
    Nov 20, 2001
    6
    I got the receiver set up very customizable clean sound through my speakers it is a keeper!
