1. Guest,
Not All Netflix/Hulu+ HD Streaming is the Same
Discussion in 'Playback Devices' started by bigshot, Dec 26, 2013.
  1. bigshot
    bigshot Well-Known Member
    Jan 30, 2008
    1,857
    531
    Stephen
    I was comparing the Netflix HD streaming on my iMac to the output of my Roku 3, and I discovered that different players get different image and sound quality.
    A kind gentleman online pointed me to this chart...
    http://en.wikipedia.org/wiki/List_of_Netflix_compatible_devices
    On top of this, if the menu screen on Netflix reads "Available in HD" it will play in HD, but if it reads "Available in HD on your TV" it will only play in HD on specific players. About a third of Netflix's HD content won't play in HD on Apple TV, computers, certain networked blu-ray players and Xbox360. The players that will play these movies in HD include Roku, PS3 and Western Digtal Media Servers. Whether or not a player is able to stream 5:1 sound is a whole different set of players that work and players that don't
    Supposedly, it's the same with Hulu+.
    When I was shopping for a set top box, they all looked pretty much the same. Now that I understand how it all works, at least for Netflix, some players are much better than others. Worth checking into if you plan to put streaming into your home theater.
  2. Type A
    Type A HW Reviewer
    Apr 7, 2007
    800
    43
    Portland Oregon
    Ty
    While its improved over time Netflix streaming still represents the least content consumed in my theater. Frankly, if streaming, I expect both poor audio and video performance. Im not sure I would ever let the particulars of Netflix playback affect my ultimate purchase decision, especially when considering a blu ray player. Interesting info, to be sure, but Im not sure the impact for home theater applications.
  3. Jim Mcc
    Jim Mcc Well-Known Member
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    My Netflix HD streaming experience is the total opposite of this. Either your player is not streaming in 1080p, or it's the fault of your ISP. Netflix HD looks excellent on my 106" diagonal screen.
    Ron1973 likes this.
  4. Pawl
    Pawl Well-Known Member
    Sep 2, 2013
    48
    8
    Netflix shows films in Super HD, and it looks crisp and clear on my Apple TV!
  5. RolandL
    RolandL Well-Known Member
    Dec 11, 2001
    3,049
    540
    Cromwell, CT
    Roland Lataille
    On my PS3 when I'm watching House of Cards for example, the picture will look like SD for the first few minutes but then will change to HD. Strange that there is no pause in the signal change when this happens.
  6. Phototone
    Phototone Member
    Mar 29, 2013
    7
    Gene McCluney
    I've noticed this on every show, although in my case, it is only a few seconds, generally goes HD before the credits end. I stream thru a stand-alone bluray player.
  7. revgen
    revgen Well-Known Member
    Apr 7, 2010
    782
    341
    Dan
    There is a Netflix video you can watch called "Example Short 23.976" that is 11 minutes long. It shows the bitrate of the stream during the video. If you're not getting 5800kbps (SuperHD bitrate), then you're not getting the best picture. Possibly due to Netflix's servers being too busy, your ISP throttling your Netflix connection (look up net neutrality), a bad router, or a bad internet connection.
    If you have a Roku player, you can add a private channel called Speed Test to check and see if it's your internet/router connection that's bad. https://www.rokuchannels.tv/speedtest/
    If Speedtest is showing speeds in excess of 7000kbps or 7mbps, then it's either a problem with Neflix's servers or your ISP is throttling the Netflix connection.
  8. mattCR
    mattCR Well-Known Member
    Oct 5, 2005
    10,469
    368
    Overland Park, KS
    Matt
    I have a Google Fiber (gigabit) connection. I have no problem with SuperHD. But let's also get real: not everything on Netflix is available in SuperHD. A ot of it isn't available in any real form of HD.
    While HD on Netflix has improved, and I find it better then DVD quality, it's clearly a short notch below HDTV line streams, and a BIG GIGANTIC drop from Blu-Ray. Netflix falls prey to some of the issues that follow any streaming format; black is not always solid and rich, fast moving films have a tendency to get left over artifacts here and there, audio is clearly not in the same category.. it's better than DVD, it's better then SD TV. It's not bad, I find it quite watchable, but it's not a competitor to say, discs at this point.
    In comparison, VuDu HDX is in a category I'd put just below Blu-Ray, but when I watch the bandwidth meter, it definitely gobbles up a much larger share, even with a 'head start' that it uses
  9. John Garcia
    John Garcia Well-Known Member
    Jun 24, 1999
    11,572
    23
    NorCal
    Many of neftlix multichannel streams use DD+ at 640kbps and sound surprisingly decent compared to DVD, but are nowhere near what you get on Blu-ray. The ISPs are trying to force the hand of Netflix by throttling them now because I was getting super HD and really shockingly good quality 3D for a while there and now get most shows in roughly SD quality even though I have a brand new faster router and good connection speed (~57mbps down). I have Comcast and there was a big article last week talking about them trying to force Netflix to pony up the funds for their own pipe by throttling them for all of their users regardless of traffic.
  10. Ron1973
    Ron1973 Beverly Hillbilles nut extraordinaire
    Nov 26, 2012
    1,552
    852
    SE Missouri
    Ron Reagan (not that one!)
    Wow, I've never had this issue. I know I've said this before in different topics/forums but I simply can't get past how good Netflix looks. Granted, I watch older shows that aren't "top-notch" like a movie but still.
    Yesterday, for instance, I picked up The A-Team on some new station on Directv. I pulled up the same episode on Netflix and it was a much sharper picture. The same goes for Emergency! Our local ME-TV affiliate shows it but it's almost unwatchable because we're used to the hi-def transfers being presented by Netflix.
    John Garcia likes this.
