Curly
- Feb 20, 2012
- Kurt Sligh
Martino said:Yes, that's correct.Another double check of the setup - all speakers should be set to the "small" setting and the sub output should be turned on.
Speaker system setting: Front Bi-amp
The Bi-amp mode is for when you want to have seperate amplification channels going to the same set of speakers - say front left tweeter and front left bass speaker sections - with your sound bar, you should not be able to bi-amp the front... Also - there should be only 1 center channel ....should be setup as: Front - left, Right Center Surrond left, Right... I will look up your manual and see - the bi-amping will end up deviding the signal in the processor and sending part of it through one of the surrond channels... --I chose Front L and R / Center L and R / Surround L AND R
Dangit...I was so close I almost choose that one, but that extra zone scared me off. Man I hope that's it. I'll let ya know tonight. Thanks again for all of the advice. CurlyMartino said:I think you want section [e] 5.1 channel surround system & ZONE 2 connection (Multi Zone) Even though you may not be using ZONE 2 - this will setup the rest of the system as a normal .... it might have been causing issues...
