1. Guest,
No audio from AV Receiver from TV
Discussion in 'Beginners, General Questions' started by editman, Jul 17, 2012.
  1. editman
    editman Agent
    Dec 23, 2011
    49
    My Samsung ES8000 TV has a HDMI connection that supports A.R.C.. It is connected via a HDMI cable (Monster 15.8Gbps ARC 1.4) to my Pioneer VSX 921 AV Receiver that supports ARC.I cannot find a way of playing the audio from the TV thru the receiver.Can any one help please
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,042
    894
    Chicago-ish/NW Indiana
    Sam
    You have to turn on CEC control on both the TV and receiver...
    Good luck with the headaches that will cause.
    ARC is a great idea implemented badly.
  3. editman
    editman Agent
    Dec 23, 2011
    49
    Considering those comments,I think I will use optical connections instead
  4. editman
    editman Agent
    Dec 23, 2011
    49
    Connected an optical cable and still have a problem. It has been connected from the optical out on the TV to the optical in TV/Sat port on the receiver.I made sure the cable “clicked” each end when fitted and the cable shows red at the amp end when the TV is on. Now all I am hearing when I set the receiver to TV/Sat is muffled base sounds from the sub and I need to put my ear next to the centre speaker to hear anything-what I am doing wrong ?
  5. schan1269
    Jul 4, 2012
    17,042
    894
    Sam
    Probably...(since I don't have a manual in front of me...)
    Turn the volume all the way up on the TV?
    But before you do that...turn the receiver down first.
    Somewhere in audio(and it is pretty much the same on ALL of them)
    You have the choice of internal speakers on/off. Turn them off.
    You have a choice of variable audio out or "fixed". If you do NOT have a fixed audio out...turn up the volume.
    Lastly, some TV...the only things that make it out the tos-link(or ARC for that matter) are the internal tuner and the inputs. Your TV "might not" output the apps???
    On our only "networked TV"(Panasonic plasma)...Pandora is stuck using the internal speakers. It doesn't have Netflix...so we don't know if it is a Pandora thing...or a Panasonic thing.
