1. Guest,
need suggestions on wall speakers placements
Discussion in 'Beginners, General Questions' started by Chap Capuyan, Apr 13, 2013.
  1. Chap Capuyan
    Chap Capuyan New Member
    Apr 13, 2013
    4
    Pretty straightforward. I need some suggestions on where to mount my front Left and Right in wall speakers.
    Here are a couple of pics of my complicated wall.
    (They are also attched)
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,038
    894
    Chicago-ish/NW Indiana
    Sam
    Return them to the store and get a LCR bar and mount it to the TV.
  3. Chap Capuyan
    Apr 13, 2013
    4
    Ah,yes. That might do it. One question though, is an L/C/R bar the same as a sound bar? I wan't to use my AVR's left, right, and center ports.
  4. schan1269
    Jul 4, 2012
    17,038
    894
    Sam
    No LCR bar is not the same as "soundbar".Pinnacle QP15Def Tech Mythos 10(if not it is the 9 or 7 or...)BIC has one in the PL series.Leon (out of Michigan) makes them custom sized exactly for your TV. Google "Leon 414"
  5. Chap Capuyan
    Apr 13, 2013
    4
    So, would an LCR bar use 3 speaker wires to receive signals from an AVR?
    Thanks for your help!
  6. schan1269
    Jul 4, 2012
    17,038
    894
    Sam
    Yes, your front three wires connect to it. And, depending on what mount you have(brand), there should be a "center speker mount" that you would use. Essentially attaching this right to the TV.Chief and Sanus models can work with pretty much with all other brands of mount.Look for the Chief PCCCA2 (on my phone so my search is limited, but the PCC i gave is close enough to find it...so you'll know what to look for).
  7. Chap Capuyan
    Apr 13, 2013
    4
    Alright. Thanks a lot sir. I think I've got all the info I needed.
  8. mccambley
    mccambley Well-Known Member
    Jun 10, 2008
    635
    2
    Casey
    How about lowering that TV. The bottom of the set should be about 36 inches from the floor.
