Rain
- Mar 21, 2001
- Rain
Also lose blue focus causes a halo too.Can you elaborate on that. I have no idea what "blue focus" means. :b
I don't know about previous models, but the KP51WS500 does not allow any kind of manual convergence in the user menu. "Flash Focus" is all you get.Yes.
Flash focus is not good unless you contantly re-train it what to do.
You can manually converge the set via the service menu, and it should make a big difference.
Instructions...
Turn the set off (standby)
Press in order on the remote- Display, 5, Volume+, then power to turn it on.
This should get you into the service menu and you should see the green headers on top to confirm this.
WARNING: ENTERING THE SET CAN VOID YOUR WARRANTY AND CAUSE SERIOUS HARM TO THE SET IF YOU CHANGE THINGS YOU DON"T KNOW ABOUT!!!!
Hit the number 2 on the keypad of the remote to cycle through the chapter headers of the service menu untill you see "PJE"
PJE is the connvergence header and should be white. When you get there, press 6 to get the grid on the black background up. Then 9 to pop up the control box. The number 3 changes color you are adjusting.
The JOYSTICK moves around and when you press the joystick in the control box turns a color you are adjusting and you use the joystick to control things.
Don't adjust green. Start with red, then do blue. Green is your guide you converge the red and blue to match.
Start in the center and work out clockwise. do one color at a time.
If you hit #1 it automatically rotates clockwise out... Neat little trick.
Mute + enter saves if you think you improved anything. If not, just turn off the set without saving and nothing will be changed.
I would recomend you learn more before you try it, perhaps even order a service manual.
Some of the Sony guys might better explain this that I did.
Steve S????
WARNING: ENTERING THE SET CAN VOID YOUR WARRANTY AND CAUSE SERIOUS HARM TO THE SET IF YOU CHANGE THINGS YOU DON"T KNOW ABOUT!!!!According to what I've been told, accessing the service menu does NOT void the warranty.
Thank you for the convergence instructions, but quite frankly I couldn't be bothered to do this myself if it's covered under warranty. Let them do the work.
My ghosting is NOT blue, so it's probably not the blue focus. However, I may as well look into that also. Do you know how to "tweak" this?
enter the service menu.Thanks for the tip, but I've already been into the service menu several times.
so far I'm pretty happy with what I've been able to do with it. Perhaps ignorance is bliss in my case.It is.
Once you learn, it's all your do. You won't even be able to enjoy a movie without first tweaking and making sure everything is set top perfection.
You'll find yourseld tweaking freinds and relatives sets. Everyone seesm to have a sony, so you'll get lots of places to practice.
Soon your be out of control.
My advice is to remain happy and stay out... It's almost addicting. You think the convergence is good, untill you get in there and discover it can get alot better.
I thought you had already done manual convergence. I figured you for a tweaker type.
I take it you have not centered your screen, or adjusted geometry? Or focus?
One easy tweak that's really worthwile given that one of the color temps is NTSC standard is the AXIS or AXPL tweak.
Sony's push red, but changing the value of AXIS or AXLP in the service menu to 0,1,2,or3 depending on which set it is will make the color decoder accurate and not push red.
Worthwile tweak to try sometime. Nice thing about sony's is if you don't save "mute then enter" then all you have to do is turn off the power and nothing is changed. So you can perform the tweak and practice a few times before you actually do it and save the changes.
Sony's are straightforward. I like that.
I take it you have not centered your screen, or adjusted geometry? Or focus?Screen is centered. I tried a little geometry adjustment, but it throws off the convergence to the point where the Flash Focus doesn't work. If I make any significant changes to the geometry, a manual convergence would be required immediately, so I'm going to wait on that issue.
How do you adjust focus other than via manual convergence?
