1. Guest,
Need Help Now!
Discussion in 'Speakers' started by Matthew Will, Jun 30, 2005.
  1. Matthew Will
    Matthew Will Well-Known Member
    Jan 6, 2002
    169
    I just finished building my ported Atlas subwoofer. I connected it and powered it up. I turn on some music. I realize that even though they've worked for the past 5 months straight, worked fine last night, even when I got home from work today but the second I am excited about my new subwoofer they don't decide to work. What I'm talking about are my right side speakers. No signal is going to them. All that is coming out of them is a low static sound.
    All I did to the system was put new A/V cables from my source to the receiver and run another audio cable from the pre-out to the subwoofer. Then I configured the receiver to know I have a subwoofer hooked up.
    I have an Onkyo 601. Why do my right channel speakers not work? Matt
  2. Matthew Will
    Jan 6, 2002
    169
    Also when I play a resonance test my right side speakers still play the bass. What is going on? Matt
  3. Bob McElfresh
    Bob McElfresh Well-Known Member
    May 22, 1999
    5,183
    Check all your speaker wires. Chances are that when you changed the interconnects, you bent some wires and are now the right speaker wires are somehow shorted.
    Be sure to check the speaker wires at both ends: reciever and speaker.
  4. Matthew Will
    Jan 6, 2002
    169
    I fixed the right channel deal.
    When I play the resonance test all the speakers still receiver the subwoofer level bass signal. Why? Matt
  5. Jack Briggs
    Jack Briggs Well-Known Member
    Jun 3, 1999
    16,740
    129
    Matthew, even though you're not asking for purchasing advice, this topic has such specificity that it really needs to be discussed in the area devoted to Speakers/Subs. Hence, its new location.
