1. Guest,
need decent "smaller" tv
Discussion in 'Displays' started by Glenn, Jun 14, 2008.
  1. Glenn
    Glenn Well-Known Member
    Oct 26, 1998
    231
    Hi,
    My daughter is going to college in August and I am looking for a smaller sized tv for her to take. I am thinking about a 26 inch tv. Are there any LCD hdtv sets less than 32 inches that are decent without spending the same amount as a 32 inch set? Maybe a tube tv would be good?
    Let me know what is out there if you know. I'm not looking for a great tv, just one that she can watch a DVD sometimes and possibly cable tv.
    Glenn
  2. Brian^K
    Brian^K Well-Known Member
    Jun 6, 2006
    681
    High quality flat-panels are pricy, yes. However, if you go for the lower quality brands (as we did when we bought things to bring to college with us, "back in the day"), there are options. I just pulled up Best Buy, for starters. Yes, there are a few 19" models that cost as much as a 32" model, but there are also some 19" models that cost less than $300.
  3. Steve Berger
    Steve Berger Well-Known Member
    Sep 8, 2001
    970
    2
    Yes, of course, there are the conventional "SDTV" or "TubeTV" models for around $150 in that size range (27" = $200): 4:3 480i CRT with analog and digital tuners. (digital tuner converts to 480i like the stand alone converter boxes) A 27" 4:3 is about the equivalent of a 32" 16:9 set for all but full HD programing.
    You might check around with your friends. Someone might have a perfectly good 5 or 6 year old analog TV in the closet that you could get for cheap or free. Personally, I wouldn't put anything of value in a shared dorm room.
  4. Bob Graz
    Bob Graz Well-Known Member
    Sep 26, 2002
    798
