1. Guest,
Need a new receiver for 6.1 and 2 zones
Discussion in 'Beginners, General Questions' started by thehunters, Apr 4, 2014.
  1. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Hi there, I have been enjoying the forum for a while as a lurker, now I have a question that I hope you all can help with.
    I'm in the market for a new receiver. I currently have a 5.1 setup with a Sony STR-DG800. I have had a rear center speaker mounted but never hooked up since I didn't have the receiver for it. I want to incorporate that extra rear center speaker (which is the same make and model as my 2 fronts and 2 rears) now with a wired networkable receiver that can also handle 2 outdoor speakers as a second zone or even B speakers. Odds are I'd never use the outdoor speakers while using the main 6.1 speakers. I guess I'm looking for any recommendations for a new receiver that can drive 6.1 speakers and handle the 2 outdoor speakers as well and handle wired internet for streaming internet radio. I'd also like it to have an Android/Apple app to control from my phone/tablets. Airplay would be an added bonus as well. And finally...price. Of course I'm looking to do this on the inexpensive end. I'm not really looking to spend more than about $300 or so and am willing to sacrifice sound quality to stay within that price range as long as it meets my tech needs mentioned above.
    Thanks for any help you all can provide here.
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,037
    894
    Chicago-ish/NW Indiana
    Sam
    Doesn't exist.
  3. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Thanks for your reply. I assume you mean the product doesn't exist in that price range. What is the low price end of a receiver that meets those needs? Is there one feature that I can eliminate to bring it down to my price range. Thanks again schan1269.
  4. Robert_J
    Robert_J Well-Known Member
    Aug 22, 2000
    8,264
    46
    Mississippi
    6.1 receivers were only around for a short time to bridge the gap from 5.1 to 7.1 systems. You may find a rare, used on on Ebay I doubt that it will have a 2nd zone.
  5. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Thanks Robert, couldn't I just use a 7.1 system to work my 6.1 speakers?
  6. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Another thought, if I can use my outdoor speakers as the B speakers, I don't need a zone 2 right? Can I stay in my price range without a zone 2? Thanks again.
  7. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    RX-V575Get one before the refurbs are gone.
    thehunters likes this.
  8. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Thanks schan1269, how would I drive my outdoor speakers AND the center rear? I don't see a B. Looks like it has everything else though..and a good price.
  9. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
  10. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    There are no 6.1. In the manual of the 575(and every other 7.1 AVR) it tells you how to run a single rear speaker.It has Zone B, no clue how you are missing it.However, if you meant 6.1 AND Zone B at the same time, math tells you that is an 8 channel (which doesn't exist...cause it is 9) AVR. The cheapest is the Pioneer 1523 as an Amazon Warehouse Deal for $780. Save up...quickly.
  11. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Thanks again for your reply. Yes, missed the Zone 2/B. My confusion lies in how I would hook up 6.1 in the main room and then my two exterior speakers. No, I wouldn't want to play both zones at the same time, but I couldn't even connect everything at the same time, right? Speaker selector box perhaps for the two front speakers? Would I loose any quality in doing that? Do you have this receiver, or were you just suggesting it?
  12. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    I thought the 575 had 9 speaker terminals. I chose the 575 cause you removed Zone 2 and added Zone B( Not the same thing, at all)...to fit your budget.
  13. Audio14
    Audio14 Well-Known Member
    Feb 17, 2014
    48
    3
    Tri-State
    Daniel
    Consider the speaker selector too
  14. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    schan, looks like I can only see 7 speaker terminals on the 575, so I'd need the speaker selector box. I just found the RX-V675 at Newegg for $380 and that has 9 terminals. Seems like a good option for not needing the selector box...right? Are there any major differences between the RX-V575 and RX-V675 besides that? Thanks again!
  15. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    It also has Zone 2...not B and HDMI upconversion.
  16. thehunters
    thehunters Member
    Apr 4, 2014
    9
    Scott
    Seems worth the upgrade for just $30 more.
