Jeremy Tebo
- May 5, 2003
Ok, folks, here is my situation. I'm less than a year out of college, and it's time to put together my own home theater. (Always had roommates with nice stereos) A few months ago, I spent a lot of money on a TV (Sony 36" HDTV - 36HS500), and now it is time to start on a home theater. I also have an old Aiwa mini system, so I'm basically starting from scratch. I'm on a limited budget (under $1000 total, including new DVD player), so any suggestions are much appreciated. I'll show you what I'm thinking about, tell me what you think.
Reciever:
Sony DE885 (Probably black)
I know Sony doesn't make the best quality audio stuff, but I like the idea of using the same brand as much as possible, and you get quite a bit of bang for your buck. This has HD component in/out, 5.1, and I can pick one up for about $250 + $30 s/h.
Or maybe the DE685, but I don't think I can run HD component through it.
Question: If I run my DVD player w/ component and my cable box w/ s-video both to the reciever, do I need to run both comp AND S from reciever to TV, or just comp?
DVD Player:
Sony DVP-NS755V
I was going to get the NS715, but for about $100 more, this gives me SACD capability. ($210 + $20 s/h) Also, the 755 got better reviews. I'd like to hear what you all think about this, but I figure the Floyd DSOTM album in SACD would be worth it alone. I tried a P-scan Phillips DVD player, but I thought it sucked, and brought it back. Now I'm back to using the PS2. :frowning:
Speakers:
This is the part where I really need some advice. I want a system that is good with movies and music, probably used more for movies/tv. Keep in mind, this is very budget constrained, I can always upgrade later.
Sony MF550H, CN550H, MB150H.
I know, I know, Sony speakers suck, right? I would agree, but I listened to these at Best Buy, and they sounded really good for the price. I can get a 5-speaker set for under $300. They clam to be for "high resolution audio" for sources like SACD. Is this true or BS? I want some bigger speakers like these, because the little ones I've listened to all sounded hollow and puny. Also, they look cool, which is most important, right?
OR
Fluance AV-HTB
These are really cheap ($200 + $50 s/h) and got good reviews on this board. However, they seem a little small, and I don't get to hear them before I buy. (Not to mention that I've never heard of them before I saw them here) I would go up the next step to the SX-HTB, but that wood grain would look like crap with my Wega TV & stand.
OR
Onkyo SKSHT500
Another entry-level set of speakers, I listened to these at Circuit City. They sounded better than the crappy mini-speakers, but still nothing great. Good price, though, and it comes w/ a sub, however stands would be required for the fronts. ($250)
OR
JBL NSP1
These got good reviews here, but I'm scared of getting itty-bitty speakers that sound itty-bitty. Also, these would require stands for the front speakers. Good price, good brand. ($210)
Subwoofer:
I'm in a 1-bedroom apartment, so unfortunately booming bass isn't an option. (My puny Aiwa system is loud enough to wake the neighbors already) I'm thinking about a sony 8" that I saw for $99, or a 12" for $199, but maybe I'll just hold off on the sub altogether for now.
Thank you for reading my novel, I look forward to constructive criticism and suggestions.
-JT
Reciever:
DVD Player:
Sony DVP-NS755V
Speakers:
OR
Fluance AV-HTB
OR
Onkyo SKSHT500
OR
JBL NSP1
Subwoofer:
-JT
