David Giesbrecht
- May 28, 2001
Do you have the Tempest wired in parallel (+ to +, - to -) for a 4 ohm load?
450W is more than enough power. You're getting caught up in analysis paralysis.I relize that maybe I'm expecting more than what I should be, and that I'm only 17 and havn't been around long enough to be considered experienced but I do think I have a valid point and some (not pointing any fingers) just arn't willing to listen because of it.
Sorry if I came off as being rude.
David, you have great extension and flatness - flat to below 20 Hz with a pair of sealed subs is quite an accomplishment! However, you want more...And the best part is I use no EQ and I get that frequency response in any listening position in the room!
The bass sounds extremly tight and smooth all the way up until the amp clips:frowning: witch was rather dissapointing for me
P.S. A 5hz test tone makes the remotes on my couch bounce
you're already past the limits of what your drivers can linearly handle.I know that you are probably right because you designed the drivers but I have yet to hear any distortion of any kind coming from the subs except for when the amp is clipping then I get this weird blobby sounding bass
Is it possible that the clip led's come on before the amp actually clips, maybe its warning that the amp is about to clip?
Hmmm ... Now, where's the problem?The problem is producing a single 5 hz sine wave is not the issue here. I'm talking about producing movie soundtracks which contain multiple sine waves all happening at once. Even if it only takes 170 watts to bottom out my Tempest with a pure 20 hz test tone that doesn't mean thats all you need to power it. I've fed enough power into them that my 450 watts per channel starts to clip while playing back LOTR and I'm certain that they are not bottoming out.
Unbridged it to 750 watts -- still pops.I think that my power is maybe not quite the same as yours was because I tried bridging my amp so I had 700 watts per driver and I had the volume on it up until the clip lights came on and I heard no popping at all.
Porting the box will only raise the efficiency in the lowest range of bass so I probably would want to keep my gain at the same level anyway.Be aware that the lower you go the octaves become closer together. 20hz - 40hz is a full octave which is about where you'll gain efficiency by 3db (and lower probably to about 15hz if using a 10db downpoint). This is the same as saying that you're gaining efficiency between 10khz and 20khz or 5khz and 20khz if you use the 10db downpoint. You said that the sub started off in a ported alignment and that you can't really tell the difference. If this is true then I would change to ported subs...or at least build a test box, see if you get the same output or more (you will) and then see if your clip lights go on (probably not)...be sure to play them at the same level using an SPL meter so you don't get fooled into turning them up until the clip lights come on...kind of defeats the purpose.
Above all else, have fun!
- Dan Hine
What is feeding the QSC? LFE out from reciever? What is the sub level output set at? It's possible your recievers output is actually clipping if set too high.Thats a good point I'll try setting the sub out level on the receiver a little lower and see what happens. I have it set at 0 db now I'll try it at -10.
Thank you for the good explination Dan and Brian!
I am sure I am not bottoming the subs when I've clipped the amp because if I was I would be able to hear some distortion or popping right?More than likely, yes. You would know if you had a problem. Are the clip lights just flickering a little bit or are the red lights staying on constantly? I really wouldn't worry about a flicker here or there. But if you've got two red eyes staring at you then it's time to adjust something.
- Dan Hine
