RobertCharlotte
- Feb 21, 2002
Check out this thread, John:
http://www.hometheaterforum.com/htfo...threadid=96041
Monsters Inc. and SW:TPM have very dynamic soundtracks. The average level is lower than some other recent releases so as to save room for the dynamic peaks.I'm all for dynamic soundtracks, but I have to admit Monsters, Inc. has a pretty darn low average volume.
I'm curious to know what the peak level of the track is. If the peak is at 0db, then certainly the full dynamic range is being used.
I don't like overly "hot" soundtracks (LOTR comes to mind), but it's equally annoying to start a dvd, only to keep cranking and cranking the level until it's comfortable.
Cheers,
Felix
Update: Disney tech person called me back and asked what the problem was. I told him that it froze at 84:01 and he said that was the layer change (which I already knew). He asked if I was able to view the rest of the dvd after that point and I told him if I stepped it forward I was able to view the rest of the movie. He then said it was happening on a few Pioneer models only and at this point he didn't know if anything was going to be corrected. He suggested I just step over that part whenever I watch the dvd! I told him that his software people and Pioneer's hardware people should get together as this has happened a few times in the past, the most recent being Atlantis. He said he had my number and if anything else happens they would be back in touch with me. Not exactly the response I was looking for.
Steven what phone # did you call ?
What kind of packaging did BV use for this 2-disc set? Are they sticking with the "digipack" used for the Jackie Brown and Pulp Fiction spec. eds., or did they give this one the double amray treatment, as with previous Pixar featuresThe case is one I have never seen before, it has a carrier attached via a "twist" insert that is removable so that rest of the case may be used with or without the extra little "leaf". I don't know if that is what you are referring to as "digipack" or not. I have not picked up a copy of Pulp Fiction:SE yet.
Maybe the idea is to let adults remove the supplements for safe keeping while the kiddies abuse the main feature.Seemed like a pretty ingenious design to me, and is likely due to trying to cut costs. The case is basically a single disc case that the extra leaf can be added to just by snapping it in for 2-disc sets. It doesn't look like the sturdiest design, but the idea was good, IMO.
The case is one I have never seen before, it has a carrier attached via a "twist" insert that is removable so that rest of the case may be used with or without the extra little "leaf".Identical to Schoolhouse Rock, and (ironically) to Shrek's, if I recall correctly.
