I think this is our content delivery network caching files. We're going to have to play around a bit - but we'll get this fixed.Weird. I see 2001: a space odyssey for this post but, when I click on the image I see Krakatoa East of Java
I wasn't seeing this information in 'portrait' mode on my IPhone.
I also didn't see it on the person's Profile screen.
It is visible on the thread in 'landscape' mode.
I have an nVidia Shield at home I can test on. Will let you know if I can reproduce. It's most likely the particular android build on that device.Not sure why, but when I'm on my Android Tab (using web browser, not app), the site seems to freeze up periodically. I haven't used the Tab much since the new launch, but the couple times I was on it, I noticed the freezes.
I played with it on a small screen device. When the postbit goes horizontal it needs to strip out most of the post bit info including name to fit everything in. I don't think we can do much about while keeping it mobile friendly. Its just on small screen sizes, its there on all the others.
I imagine this is more of a specific computer/browser issue than a site issue in general, but I'm unable to use the "quote" function on Firefox. It's working fine for me in Chrome.
I'm using Firefox 38.0.5 on Windows 7 and the Reply/Quote function is working fine...
FF44 here... no issues. Someone mentioned having to hit "Insert Quotes" in the editor with FF. It took me a bit to find that at first but after it was found, it's not bad. Much easier then having to select "multi quote" rather than "quote" or getting it wrong and having to do it all over.I'm using Firefox 38.0.5 on Windows 7 and the Reply/Quote function is working fine...
I'm going to guess the confusion here is that when a member is typing in the edit box, they see their avatar on the left-hand side (like a normal post bit) but all the identifying info (including their name) doesn't display.
I don't think this needs to be changed. I could just see where it might be confusing.
So I put that quote in manually... but I'm using Firefox 43.0.4 on Windows 7. When I click the "quote" button on a post, the "+" next to the word quote turns into a "-" but the quote doesn't paste into the reply box, and there is no option to insert the quotes (unlike in Chrome, where I see an "Insert Quote" button at the bottom of the reply box).
But this is me on a work computer that I have no administrative control over, so it's entirely possible that it's just a combination of settings on my end that can't be adjusted. Not the end of the world by any stretch - just slightly odd. So definitely don't waste your afternoon trying to debug it or anything!
David - we have implemented this. We're still tweaking appearance, but it should do what you need.Is there a way to put all the tags is a line of there own at the top of the page/header/?? so that they're all in one place and you could click it immediately rather than have to search for a post with the tag you need.
Can the Large Colorful ID tags be placed in the second line by Poster or maybe after the thread title instead of in front? Or possibly over on the far right side where it lines up with the sticky pins in a column of their very own. That would allow the 1st letter of the titles to line up and make it easier to scan with your eyes.
