1. Guest,
MCACC setup on Pioneer Elite receiver
Discussion in 'AV Receivers' started by bgnreau, Jan 2, 2010.
  1. bgnreau
    bgnreau Auditioning
    Dec 20, 2009
    12
    Hello,
    I was setting up my speakers through the MCACC option on my receiver and when it had gone through all the initial steps it told me that I have my back surrounds possibly out of phase. Now, I have a 5.1 setup but I am bi-amping my fronts, so I don't have back surrounds. Would that be the reason for the "error" message? After rechecking the wiring I am phased okay. I went through the rest of the set up and everything sounds okay, any ideas??
    Bruce
  2. 27dnast
    27dnast Agent
    Jul 24, 2009
    31
    my new pioneer gave me a similar error message (and it turned out to be correct)... but it noted on the MCACC screen that if I check and there was no phase error in hook-up to proceed and ignore the warning.
    ta
  3. Jidonsu
    Jidonsu Auditioning
    Jan 4, 2010
    3
    When you set up your speakers in the menu, did you make sure to choose "Bi-Amping" as the option under Back Surrounds. You have the option to choose Large, Small, No Speakers, or Bi-amping, or something to that effect. Good luck.
  4. bgnreau
    bgnreau Auditioning
    Dec 20, 2009
    12
    Hi,
    No, I didn't notice that option. I will try again and pay more attention. Will the bi-amping feature change my fronts to small as other members have recommended or do I disregard that since I am bi-amping? Can I do both bi-amping and small? Thanks!
  5. bgnreau
    bgnreau Auditioning
    Dec 20, 2009
    12
    Hi Jidonsu,
    I went in an manually changed the settings. They did indeed have bi-amping as an option and also small for the fronts with 80Hz crossover. Thanks for the advice as the receiver now sets up under "digital" and takes care of all the options proceeding from the TV receiver's(direct tv) signal. Sound is amazing! Great answer.
