1. Guest,
low profile swivel wall mount
Discussion in 'Home Theater Projects' started by hondaprlud, Jan 15, 2011.
  1. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    Can someone recommend a swivel wall mount that is very low profile when pushed back against the wall? Ideally less than 1.5" and less than $100.
  2. Jim Mcc
    Jim Mcc Well-Known Member
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I don't think it exists, by design. If there's only 1.5" of space, how can it swivel? I guess it would only swivel 1.5" then hit the wall.
  3. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    they pull out on an arm then swivel, like this one.
    http://www.sanus.com/ca/en/products/visionmount/full-motion-mount/VLF311
    This is exactly what I'm looking for, just way too pricey. I'm trying to find an off brand or something that will be cheaper
  4. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Try Monoprice.com
  5. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    That did it. Thanks!
  6. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Did you buy a mount from Monoprice? Which one?
  7. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    [​IMG] 6519
    Recessed Adjustable Tilting/Swiveling Wall Mount Bracket for LCD Plasma (Max 198Lbs, 37~60inch)
    This one. It's recessed, so it'll be a bigger pain installing, but the price was right.
  8. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    By recessed, does that mean the drywall has to be cut out? I'm also looking into wall mounts. Thanks.
  9. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    Yes, they had a ton of options, but none that sat very close to the wall without cutting into the wall, like the one from Sanus. My TV is less than 1' thick so I really wanted something that held it tight to the wall but also could extend and swivel. I had planned on running the cables behind the drywall anyway, so for me it just means the hole will be bigger.
  10. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I was looking at your mount last night, and noticed that you have to cut the middle stud out. Did you see that? That's a lot of extra time and work involved.
  11. hondaprlud
    hondaprlud Member
    Oct 30, 2008
    11
    I was aware, but thanks for the heads up.
