1. Guest,
Lose picture when changing tv channels 720 to 1080
Discussion in 'Displays' started by Jim Tree, Apr 23, 2013.
  1. Jim Tree
    Jim Tree New Member
    Apr 23, 2013
    When changing HD channels through Comcast cable box I briefly lose the picture when broadcast resolution changes from channels (720 to 1080). When using the pass thru on my Yamaha amp the picture will not return at all. The cable box has to be turned off then back on.
    I have checked everything, all settings, HDMI cables, and inputs and replaced the cable box. I even sent the amp back to Yamaha for testing. They could not duplicate the problem. Comcast says I have excellent signal strength.
    This is a new amp, about 6 months old. It worked fine when it was first hooked up.
  2. Mike Frezon
    Mike Frezon Moderator
    Oct 9, 2001
    35,884
    4,570
    Rensselaer, NY
    Jim:
    Welcome to the HTF! :welcome:
    This sounds like one of those PITA problems. Have you actually tried different HDMI cables?
  3. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,379
    32
    New England
    Gregg Loewen
    hi
    I highly doubt the cables are at issue.
    When the resolution changes the HTPC hand shake needs to re occur. something in your system is not working (most likely a 1.2 or 1.1 device).
    I would try / suggest 1 of 2 things:
    1. make sure your amp is in pass through mode and not trying to convert the image resolution.
    2. lock the cable box output to 1080i only.
