1. Guest,
LCD Video Noise
Discussion in 'Displays' started by Adam Sanchez, Sep 26, 2005.
  1. Adam Sanchez
    Adam Sanchez Supporting Actor
    Oct 4, 1999
    908
    Hey all,
    I recently got my first LCD TV. I wanted to ask about something because I am honestly not sure if it's an "issue" or not.
    I have a Sony 32 inch LCD Widescreen. It's a Bravia, but not the XBR, it's the midgrade Silver one. When I watch a source, which in my case is exclusively DVD's, any DVD I play is very noisy in the video. I can see the back of scenes "Move" like a grain motion. My TV does have a Noise Reduction Setting that if I put on high, stablizes the image perfectly.
    I guess what I am asking is in the realm of LCD TVs, should I be having to use that NR option and particularly on high? Is that just a normal thing for LCD TVs?
    Is there any downside to using the NR feature? Just for comparison, if anyone else uses a simular feature, I would like to know.
    MY DVD player is a brand new Sony upconverting DVD player. Though I am not using the Upconverting feature yet, the cable is on order. (HDMI) For now I have it hooked up via S-Video, so I'm not even seeing 480p. I'll be glad when I can fully use my player!
    So anyway... thoughts on that NR? Thanks!
  2. Adam Sanchez
    Oct 4, 1999
    908
    Anyone? If something is wrong with my Set... I need to find out so I can exchange it.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I was holding back comment until you can try some Component and/or HDMI connections.
    You should really only need noise reduction on bad NTSC sources, even then it is questionable usually having some trade offs to get the cleaner looking video.
  4. Adam Sanchez
    Oct 4, 1999
    908
    Oh ok. Getting the cable will still be about a week away. So I shouldn't be having to use the NR feature? Like I said it just clears the picture up... it gets rid of the "GRain motion" I can see around images. I hope I am explaining that clear enough.
    Is there a downside to using the NR? Or to the point, is something wrong with my TV? Some salesman I think it was told me all LCDs have a bit of noise when you buy them... till the set is broken in a bit. I don't know if I should buy that explanation...
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    NR can at times introduce it's own set of oddities. I know I have even seen it clip both blacks and whites on various displays. As in you can't calibrate correctly with it on.
  6. Larry Hoffman
    Larry Hoffman Stunt Coordinator
    Jul 2, 2001
    103
    Just wondering, would lowering the sharpness help? I know it causes CRT's to look lousy when up too high.
    Larry
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    That is a great point Larry.
    I didn't even ask if he attempted to calibrate or anything.
    Try playing around with the THX optimizer and see if you can gain any improvements Adam. THX Optimizer is available on many modern DVD's, not as good as a real calibration disk, but at least can get you in the ball park and provide lots of improvement.
  8. Adam Sanchez
    Oct 4, 1999
    908
    I have calibrated it a bit but not too much. My sharpness I know is less than 10 right now. I have alot of DVDs with the THX optimizer. I also have a Home Theater Enhancement Disc I got with a disc cleaner that I use, though it's pretty basic. I also have Avia, I actually downloaded it the other day. (Yeah yeah) but it has soooooooo many config screens... damn!
    Since I'm waiting for an HDMI cable and I am going to have to calibrate all over again, I have not thoroughly went through Avia. I'm using S Video right now and just kind of eyeing the picture.
  9. Adam Sanchez
    Oct 4, 1999
    908
    I hate to ask this but would someone mind explaining (Or linking me to) exactly what the Cinemotion (3:2 pulldown) actually is, does and it what situations am I going to want to use it?
    Thanks!
    By the way I just tried to tweak my system using the generic DVD I mentioned I have and I can't get the black level even close to right. I literally had the settings full blast and still could not see the lighter of the black bars... actually I couldnt see any of the black bars used in the test. Maybe it's because I'm using S-Video.
    Again, not really gonna worry about it till my HDMI cable gets here. If I still can't see the test... THEN I'll be worried. [​IMG] Now I know why Quantam Leap seemed so Dark though!
  10. John S
    John S Producer
    Nov 4, 2003
    5,460
    3:2 pull down is a way to get film (30 frames per second)based material to nearly flawless 24 frames per second (Video).
    You would want it on film based DVDs and Laserdiscs, well VCR too I suppose anything film based fed to the display Interlaced 480i. [​IMG]
  11. Adam Sanchez
    Oct 4, 1999
    908
    Do all TVs have it or is it something LCD Tvs specifically need? My old normal TVs never mentioned anything like that but of course the images always moved fine as far as I could tell...
    It's only for 480i? So once I am using Upconverting HMDI, I can turn it off?
  12. Adam Sanchez
    Oct 4, 1999
    908
    I got my HDMI cable today but have not had time to do any calibration. I have a few questions though, some may seem really dumb so forgive me.
    Is there a way to know what my sets "Native" or optimal resolution is? It supports 480i, 480p, 720p, and 1080i but I was just wondering if it has a certain setting that is ideal.
    Also on my upconverting DVD player, which is better, 720p or 1080i? I have a feeling that is a very loaded question...
  13. Rich Romero
    Rich Romero Supporting Actor
    Jun 6, 2002
    731
    Well, it all depends. 720p I'm assuming is your TV's native resolution. Either 480, 720, or 1080 could look better to you. It varies by the setup and on a 32 inch it may be hard to tell. I have a SONY LCD and the picture is gorgeous. However, it took me a while to tweak it. I recommend searching the AVS forum for your TV model number and getting settings suggestions from them.
  14. Adam Sanchez
    Oct 4, 1999
    908
    Mine is a 32 inch Sony as well. KLV-S32A10. The TV supports all those resolutions, but I guess that doesnt nessicarily mean which is native or optimal huh?
    I still have that video noise even in HDMI by the way. I may never know if it's normal or something is wrong with a part of my equipment. Guess I can't worry about it anymore. I just have to have that NR on high and I don't know if that setting has any adverse afects.
  15. Rich Romero
    Jun 6, 2002
    731
    Noise Reduction should be on either Low or Off. If your settings are correct, there shouldn't be that much video noise.
  16. Robert James Clark
    Robert James Clark Second Unit
    Oct 25, 2001
    353
    All LCD's suffer to some extent from what's called "FPN" or Fixed Panel Noise (or Fixed Pattern Noise as it's sometimes called) which can cause a momentary gridlike appearance in moving scenes with solid color backgrounds. The more extreme case of FPN is called Vertical Banding (VB) which causes vertical lines in the above condition. When you have it, it's a bit more noticable than FPN.
    Could this be what you're seeing? It's fairly normal. But it sounds like your problem may be source related.
    I wouldn't crank the sharpness up on any display. Try to calibrate it with Video Essentials or Avia or some similar tool.
  17. Adam Sanchez
    Oct 4, 1999
    908
    I have tweaked the heck out of my system using Avia, I did it last night. Sharpness is very low. I should have NR either low or off? Uh oh... that's not what I was hoping to hear.
    Still, is this probably source relatated? It's definately not the TV?
    What would be a good movie, or type of movie to test the noise? I have alot of DVDs, and all of Pixar's films. Would the digital transfers of those maybe be a good test bed? Thanks for suggestions.
    That could be it. I can just best describe it as grain motion around scenes and backgrounds. It's partically noticable in dark scenes. It's also really really noticable on older shows on DVD. I was just watching Quantam Leap for example.
  18. Robert James Clark
    Oct 25, 2001
    353
    Is it around the edges of objects?
    That would probably be source related.
    I can't think of a good test for FPN or VB off the top of my head. Any solid color background on a panning motion shot. I'm surprised you're seeing it in dark scenes. That doesn't sound like FPN. It should look like a texture or even a slight emphasis of screen door. It's sometimes described as the "dirty screen" look.
  19. Adam Sanchez
    Oct 4, 1999
    908
    Last night I had a chance to watch my first live action movie since I got my upconverting DVD player and I'm happy to say my set is now looking freakin gorgeous. I dont know if its the upconverting but the whole time I kept saying to myself "Damn this looks clear."
    I watched The Rock Criterion and it looked excellent AND it has no video noise. I think I had the setting between low and off but either looked fine. I think my TV is finally set, so I can stop worrying. I'm seeing the picture I thought I would see after paying $2000!
    My problems have definately been source related. Not DVD or TV, but the DVDs I was watching. I will remember next time to TRY OUT MORE DISCS! [​IMG]
    Thanks for all the replies.
  20. John S
    John S Producer
    Nov 4, 2003
    5,460
    HDTV's are so good, they reveal less than steller transfers from film to DVD easily.
    Not all transfers are created equal, that is for darn sure.
    I even have a few instances where the transfer on my laserdisc is better than the transfer to the DVD I purchased to replace the laserdisc.
    The majority of DVD's are fantastic, but there are a few that people notoriously complain about the transfer or copy of the film that was used for it.
